20 Most Recent
Alessi SG68 2Slice Toaster Questions & Answers
The arm that holds the
There's no diagram available but an actual sketch image. Find it below, also important as it shown how parts was also put together. The next images was the manual for this unit.
I hope everything you need can be easily explained by these images. If
you have other questions let me know so I can help you further.
Thank you for using Fixya.
Alp
Only one side heats up
It is possible that the heating coil has burned up on one side and the contacts are open. so if you can open the cover and get access to the coils then check continuity so as to join the burnt lines .
This will make the heating coils to work.
make sure that you join the open wires with only thermal resistance wires.
Alessi kettle: The switch doesn’t budge, so I can’t turn it on.
The kettle in the illustration is designed for a hob and doesn't have a switch...
There is an electric version available at what I consider a grossly inflated price of £218 in the UK.
Like many other appliances, kettles used to be easily and cheaply repaired by any handy person but the arrival of the jug kettle and then the dreaded disc element made repairs more expensive than a replacement and they became a throw away item, especially as spare parts stopped being standard items and for most models either weren't available or were available but were priced not to sell.
I have little doubt the kettle will have to be at least partly dismantled to discover the problem.
I would like to know there are spare parts available for this kettle
before I started taking it apart because plastic can be an unreliable material after regularly being heated for a while and the process of dismantling a mass produced item isn't always intuitive.
It might be better to contact the manufacturer to check if they offer a repair service.
