20 Most Recent
Sony BDVE300 Theater System Questions & Answers
Problem with my Sony Blu-ray player not wanting to
There is a firmware update for that model. Try updating it. If that does not help, you may need to send it in for repair or buy a new one.
http://esupport.sony.com/US/p/swu-download.pl?upd_id=6665&mdl=BDVE300
Push power protector
It is possible
that the amplifier had encountered a fault with a higher current drain which
had triggered it to a protection fault condition. The fault can be with your
output drivers. Please check for short on the outputs fitted for both the channels.
Use a meter after disconnecting to check for short in the drivers. Disconnect
the positive and negative voltages to the output and see if the protect
changes. Even a fault in the preamp stages that drives in high current into the
output can shut the Amplifier. Sometimes this can be a noise which can be a HUM
or HISS before the protect works. Faulty capacitors in these circuits also can
cause similar issues and needs close observation.You need to confirm and
replace the specific stages or outputs. If not there can be issues in the
mother board. Maybe the protect circuit by itself is shutting off due to a
faulty bias or there is a leak in any voltage/current sensing circuit. Also
disconnect the speakers and test, if the amplifier comes out of the protect
mode then check for short on the speakers.
My sony bdv-e300 started not
Did you figure this out? I upgraded firmware from 009 to 011 and am now having the same problem. Have had the unit for 18 months. Called Sony and they want me to ship in for 147.00 dollar repair even though their firmware upgrade caused the problem. Cannot operate disk now when trying to load a Blu-ray disk. Plays standard DSD's without any trouble.....
Sony bdv-e300
Cooling fan or blower
This is not a part that is typically replaced and is not listed on the standard replacement parts list. Try cleaning out all dust that you can see. Then, if you have access, try oiling the motor itself. Quite often all that happens is that some dust gets stuck in the oil and creates an imbalance.
Please keep us posted.
Thanks,
Dan
Sony BDV-370 DVD/5.1 theater hooked to Sony Bravia
Three things can cause this:
1) not all HD is recorded in surround sound. You can very well watch an HD program that just has Left/Right stereo audio. Tombstone on bluray is even only in Dolby 2.0
2) wrong connection is used. If you only use red/white analog stereo cables you will only get sound out of the left/right mains.
3) setting on the cable box is set to stereo and not surround. Changing this varies by cable box manufacturer.
Sony BDV-E300 doesn't open Tray
See the below side of the set there is a hole use hair pin to eject your disc.Do not too much force on it other wise you will broken any part.
Connecting SONY TA-D505 amplifier LBT-D505
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier?
You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505
Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner
To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations
I hope you have my comments
Greetings Franco Dosil
Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505?
Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505
Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505
Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas
Espero que te sirvan mis comentarios
Saludos Franco Dosil
https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
