20 Most Recent
Panasonic Lumix DMC F3 Digital Camera Questions & Answers
Panasonic Lumix DMC F3 drives download
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
My panasonic lumix has a
I think it must be a fault with the camera as we brought one for my daughter for christmas and had the same problem.we exchanged it and it was ok for a couple of weeks but the black mark has appeared on this one now so we are returning it and asking for a refund.
How i copy photos from my pc to my panasonic lumix
You really can't. You can copy images on your computer to an SD Card and then insert the SD Card back into the camera. But, doing this after editing could mean that you will not be able to see those images on the camera anyway.
My cammer not compactible with windowa XP
It doesn't matter to the camera what operating system you have on your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Why My camera is not compactible with my pc, dell window xp
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Pictures are all too dark even with flash
Go to Menu find Adjust ISO settings in camera it may be on Auto or at low setting . The Higher the setting in ISO the lighter the picture this is commonly used in low light settings.Play with it until desired ISo works for you . Nice camera nice lens !
im 14 and i got
This is a faulty or damaged LCD screen. The fact that the pattern of dots and lines is unchanged by zooming and appears on the menu screen confirms it.
The LCD cannot be repaired, it must be replaced. As long as the fault is not due to misuse (such as being impacted or dropped or getting the camera wet) then the damage is covered by the manufacturer's warranty. Contact Panasonic in your country to arrange a free warranty repair; they will normally require proof of purchase and will check the camera to look for evidence of misuse when they receive your camera. If they find any then the repair becomes chargeable.
I hope that my speedy and free reply has been of use to you; please take a moment to rate my answer.
I cant transfer pictures from my camera when I connect it just tells me to scan
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
How do i transfer saved images from the PC back to
For most cameras, this is not only not possible but, even trying it can cause problems with your camera.If your pictures are being automatically deleted after downloading, it's usually because the program you use for downloading is set to do that. If you don't like that feature, you will need to go into the settings area and change it. Or, you could just download to a folder you create on your desktop. That way, your pics are still on your memory card and you can now send the pics in the folder to any program you like.
