20 Most Recent
Toshiba estudio 305 Copier Questions & Answers
Error code E731
Stop jam at the exit sensor: The trailing edge of the
original does not pass the exit sensor
There no mentusb2.o in the directory
"Store the update program loader (mentusb2.o) in the root directory, and store" Is that the directory you mean? The 'root directory' is a computer term Maybe goto here:
http://fyi.toshiba.com:81/KB/file_uploads/7802/es455-manual-update-instructions.pdf
TONER NOT recognized
First, make sure you have a Toshiba authorized toner.
There is also a switch at the rear of the machine that does go bad, sometimes just by cleaning the cavity with a vacuum may correct the problem but ive had to replace the switch before. Not something a non tech person can do.
Call for service
try to press clear+8 to show what error code is indicating.tell me what error code is that.
