20 Most Recent
Toshiba e-Studio 232 Black and White Copier Questions & Answers
Failed to connect to smtp server
hi
Most common reason for 'Outlook cannot connect to SMTP server' error is the wrong configuration settings of Outlook. This happens especially in the case of newly configured email accounts.
A mis-spelled mail server name to a wrong port setting in Outlook can cause connectivity issues to the mail server and end up giving error while trying to send or receive mails.
By default, the port settings for mail related services are these, and a connection problem to these ports can lead to Outlook error:
SMTP - port 25 / 587 POP3 - port 110 IMAP - port 143 Secure SMTP (SSMTP) - port 465 IMAP4 over SSL (IMAPS) - port 993 Secure POP3 (SSL-POP) - port 995
There are also chances that some web masters may have duplicate profiles in Outlook, which will have an old mail server configured in it, and therefore would be trying to connect to the wrong mail server.
Toshiba eStudio 210c grey background on copies
U need to check your developer material. How many copiers has been made?
U can also perform 05-200 for the auto toner adjustment. The value should be in the range of 235-245% ( 2.35v - 2.45v )
Scan feature greyed out on Toshiba eStudio 232
You have to have the USB stick to enable the scan.
It locates on the right side near the back of the machine.
They make , print dongles, Scan dongles and print scan dongles. But that USB device enables scan.
I get the error message
What email client are you using? THe scan app is not able to access the default mail application or the application is wrong.
Toshiba e-Studio 232 is showing error message CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Call for service c010 how to solve it?
C010 indicates main motor problem...U need to open up the back cover, perform output test to check whether the main motor is working. 03-101(ON)/151(OFF)
Toshiba e-studio 232 code C970
C970:
HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
Signal f103
You have a corrupted hdd promblem on you toshiba. You should find another hdd and the firmware and make them using usb stick
