20 Most Recent
Prestige Portable 320gb Usb 20 IOMEGA 34342 320 GB Hard Drive Questions & Answers
Defrag
i think ther is some bad sector tray to use this prog to test your hard disk http://hdd-regenerator.en.softonic.com/
5/7/2013 8:21:52 AM •
Prestige...
Answered
on May 07, 2013
How do i format to fat32 using windows 7
Windows 7 will format an external partition to FAT32, as long as it's 32GB or less. "Control Panel -> System and Security -> Administrative Options". Right click on "Computer Management", select "Run as an Administrator", double-click on "Storage" then "Disk Management", the right click on your external drive. Select "Shrink Volume", shrink it by 32GB or less, then right click on unallocated space, select format, and "FAT32" will show up as an option during the format wizard.
This is a way to create a small bit of space on an external hard drive for copying some files from Mac OS's to Windows.
1/7/2013 8:58:05 AM •
Prestige...
Answered
on Jan 07, 2013
Computer doesnt recognize drive
Try a different usb port on the computer. Maybe the usb port you are using is bad.Try the portable drive on another computer and see if it is recognized. If not, the portable drive might be defective.
6/7/2012 7:23:37 AM •
Prestige...
Answered
on Jun 07, 2012
250GB Prestige USB 2.0 Portable
click start control panel
administrive tools ,computer management ,device manager look through all
of your devices if you see a yellow question mark?or exclamation mark
! or red x
right click to reinstall
drivers or
if you can see your usb but
its not working
ports(com&lpt)right
click update driver
sometimes the wires inside
the cable will be damaged due to bending or stretching or placing heavy
equipment upon the cable,
just replace the cable of
the hard disk, when you plugged the external disk drive you got that
windows could recognize the USB device change the cable everything should work
fine again,
check the USB leads that
attach to the motherboard usually red-white-green-black make sure they are
securely seated and have no dust build up on them dust will cause static and a
lot of unforeseen problems also make sure the computers Ram and Cmos battery
are securely seated
or you might have to install a usb 2 or 3 card they are cheap and
easy to install you can buy these on Ebay very cheap if this solution does not
work and you might need one
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=280406610810&ssPageName=STRK:MEWNX:IT $1
+ $2.46 postage worlwide
You might get these on Ebay
im not sure which country you are in this might guide you to one
you could get this on Ebay
if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal
login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration
password ,bank card /credit card phone numbers home/mobile ,email adress
and a postal adress
be very specific when you
type in the search
always ask questions?
before you make a purchase and keep the email/s for security reasons if the
item arrives and its not as described
you will even see the
pictures of your item so you cant make a mistake and get them home delivered
hope this helps
7/26/2011 8:10:35 PM •
Prestige...
Answered
on Jul 26, 2011
I have tried connecting my Iomega 250 gb USB 2
First try connecting this USB drive to a different computer.
If this did not work then the USB adapter case is faulty, then remove the hard drive from the case and attach the hard drive to an USB hard drive adapter then plug it into a working computer's US port. If the hard drive is OK then the computer will see this as an external storage device and you can open the folders and files to backup the data off this hard drive.
If this does not work then there are companies that can recovery data from faulty hard drives BUT it will cost you an arm and a leg for their services.
10/21/2010 10:14:28 AM •
Prestige...
Answered
on Oct 21, 2010
Portable hard drive won't save info. Message says
While the drive is attached to your system and you can access it, open "Computer" or "My Computer" (depending on your operating system), then Right-Click on the drive and a menu will appear. At the bottom of that menu click on "Properties" and then make sure the drive is not marked as "Read Only". Also, go to the security tab in the "Properties" window and make sure your Administrator account and User account have Write Access to the drive.
If the above does not resolve your issue, make sure there's no write protection switch of some sort on the drive. I've never seen one like that, but it's worth checking.
Also, you could try unplugging the drive, reboot the computer, then plug the drive back into the computer once it boots back into Windows.
I hope this helps!
Best Regards,
James
6/3/2010 4:23:00 PM •
Prestige...
Answered
on Jun 03, 2010
PC not recognising Iomega Prestige 320gb usb portable hard drive
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
3/8/2010 11:05:56 PM •
Prestige...
Answered
on Mar 08, 2010
I connected a 12V Iomega MDHD360-UE Hard Drive to a 16V Power supply
that is now a cooked drive a la 16v way too much input voltage for that unit. you might get lucky though and have a drive recovery specialist extract the data from the platters. check online or in phone book for data recovery folks who usually charge around 50 bucks to tell you the old good news/bad news story
5/21/2012 2:04:44 PM •
Prestige...
Answered
on May 21, 2012
