20 Most Recent Coleman Wind-Resistant Lighter Questions & Answers
0answers
Coleman manuals
Be the first to answer 8/22/2014 3:03:52 AM • Coleman... • Posted on Aug 22, 2014Be the first to answer
I can't seem to locate the electric connection port for a 1210 coleman pressure washer.
power cord was installed on front to machine. yours not there cord has been cut.
7/29/2023 4:35:47 PM • Coleman Garden • Answered on Jul 29, 2023
What should the water pressure on the outlet side of the hose adapter on a coleman hot on demand unit.
that would be completely unknown since fixya has no idea what your water supply is
8/15/2022 1:04:44 PM • Coleman Garden • Answered on Aug 15, 2022
Coleman 5000 runs about 10 minutes at normal idle. producing 115-120 volts, then surges to full throttle for about 20 seconds, then back to normal idle for 10 minutes, then repeats.
Possible idle control module failure. Try running with idle control disabled and see if problem abates.
10/26/2019 9:39:44 AM • Coleman Garden • Answered on Oct 26, 2019
I have a coleman clean machine 1100 .it was working well and then it just stoped shotting water. i took off the nozel cleaned it reconnected the end,it spit watter then stoped again. any ideas?
Please send a picture of the pressure val. My unit runs good and water flows through it but I can't get the pressure that I need.
The head of the wand slides in and out water runs through it when the head is pulled out but will not run when the head is pushed in could it be clogged?
7/15/2019 1:23:34 PM • Coleman Garden • Answered on Jul 15, 2019
2answers
Im looking for instructions to set up a coleman screened canopy for model 9295 101c
You might try contacting Coleman by phone or online when open Monday through Friday 8:00am - 5:00pm CT https://www.coleman.com/contactus/ https://www.coleman.com/search/?globalsearch=instructions&lang=default
6/30/2019 8:07:29 PM • Coleman Garden • Answered on Jun 30, 2019
Coleman press. wshr mod apw 2200a trips breaker when let go of trigger. Pulses then deadheads then trips. Works great if keep gun on. Shut off mechanism functions but pulses then stops and stalls.
indicates problem pressure control regulator that is not by passing the water when the trigger is released causing the motor to overload
8/11/2018 10:04:10 AM • Coleman Garden • Answered on Aug 11, 2018
Fix hard pull for 1000W Coleman Powermate generator?
check that the plug is not too long and hitting on the piston next check the sump oil level as the oil sensor may be cutting of the spark
5/13/2018 9:24:23 PM • Coleman Garden • Answered on May 13, 2018
Coleman PM0435001
When you cleaned the carb did you clean the fuel jet that is in the carb. Quite often it is the screw that holds the fuel cup on the carb. If that little hole has any dirt in it the engine will not start or run.
3/8/2018 4:44:39 PM • Coleman Garden • Answered on Mar 08, 2018
Adjust water pump pressure
pressure control valves are non adjustable They operate to unload the pump when the trigger is released What can vary pressure is the jet size at the end of the wand The screw and nut on the valve is only to regulate the stop/start pressure as the trigger is pressed/ released low pressure at the wand jet can be from low water supply to the pump or pump internal problems
2/13/2018 11:11:17 PM • Coleman Garden • Answered on Feb 13, 2018
I cant pull the starter cord on mt coleman ct200u
Remove cover over starter pulley. Cord wraps around this. When cord is pulled, centrifugal force swings spring-loaded weights out, to engage the starter gear. Check that weights are releasing when not pulled. And that cord is still on pulley. May have wound off the side.
11/22/2017 10:43:27 PM • Coleman Garden • Answered on Nov 22, 2017
Coleman Wind-Resistant Lighter Logo
1 questions posted
Top Coleman Garden Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Coleman Garden Expert? Answer questions, earn points and help others
View Most Popular
Coleman Garden
  • Coleman Garden
Most Popular Question
seem locate electric connection port
  • Garden
