20 Most Recent Coleman Pressure Washer PW0881800 Questions & Answers
2answers
When i try to use a cleaning additive, my pressure
most pressure washers have a special nozzle when using the cleaning part to reduce the pressure and **** the solution from the tank. Check your owners manual and if not give me the brand and model number and I will check into it.
11/11/2016 10:34:05 AM • Coleman Pressure... • Answered on Nov 11, 2016
Coleman 1210 power washer no water comes out of gun
I've never used it before what plugs in where, the 1210 powermate, Pictures would help
1/6/2013 7:57:45 PM • Coleman Pressure... • Answered on Jan 06, 2013
My coleman powermate 2750 pressure
All i can say is its not a good mechine I owen and repair washers and pumps and use them in line of business thats all i can tell you sorry
8/19/2011 10:31:17 PM • Coleman Pressure... • Answered on Aug 19, 2011
My neighbor was getting rid of an old coleman
The Manual for the Coleman Pressure Washer PW0881800 can be found here:
http://www.powermate.com/pdfs/2007/11/30/manual_pw0881800.pdf
Refer to page 5 of the Manual for the start-up procedure.
6/28/2011 8:37:55 AM • Coleman Pressure... • Answered on Jun 28, 2011
0answers
Hello sir, how to change oil of my 1800 water
go to -:LINK.
10/13/2010 10:48:30 PM • Coleman Pressure... • Answered on Oct 13, 2010
When the spry trigger is pressed the engine boggs
This issue is caused by defective unloader or debris trapped in spray nozzle or faulty gun. Easy to check. Check system with-out spray nozzle. The engine should not labor at all when you depress trigger without nozzle. If it labors/ dies faulty gun, if no labor, install new or clean nozzle (check for correct gpm for machine) and retest. If ok, you are done, if engine labors or dies, reduce pressure by turning pressure knob as required. If reducing pressure has no effect, most likely faulty unloader. Good luck
10/6/2010 4:15:37 PM • Coleman Pressure... • Answered on Oct 06, 2010
0answers
It shuts off during use then starts right back up.
Most of the time it is due to fuel lock - very hot engine. Easy to check, run engine with gas cap loose (not with full tank, fuel may spill out). Replace cap or open vent if necessary. Other problems include low or dirty oil causing oil senser to shut down engine, or hot engine due to obstruction of airway under cover and finally pressure set too high. I find that most pressure washers are set to max pressure. I like to set pressure to 70 % of capacity making components last longer. How long would a car/truck last if you drove it at max speed everywhere? Good luck with your repair.
7/8/2010 4:11:08 AM • Coleman Pressure... • Answered on Jul 08, 2010
I have a Coleman 1800 pressure washer and it won't
sounds like the air filter may be blocked or the carb has a dirty jet in it
3/27/2010 11:27:34 PM • Coleman Pressure... • Answered on Mar 27, 2010
Striped pressure outlet connection
Here is a link to a company that sells stuff for your machine.
link
Rate this if it helps you.
1/11/2010 3:44:31 PM • Coleman Pressure... • Answered on Jan 11, 2010
Electric Model # pw0751250 replaced
I suggest you change out the handle. It does not have to be the exact same one, since you can "adapt" the connection to virtually any power washer handle. If you have a "Northern Tool and Equipment" nearby, they stock a variety of handles...The complete assembly, handle wand and all starts at about $30...and goes up from there. If you do not, you can order on line. Here is a link to help you locate a store, brouse parts, and/or order online. Hope this helps. Good luck!
http://www.northerntool.com/
10/17/2009 6:36:55 PM • Coleman Pressure... • Answered on Oct 17, 2009
0answers
I have a Coleman 2750 power washer that just idels
Possibly has leaking seals or there is a blockage in the gun or hose. remove the hose first and see if it is putting out enough water.
7/31/2009 9:34:25 AM • Coleman Pressure... • Answered on Jul 31, 2009
Coleman Pressure Washer PW0881800 Logo
37 questions posted
Top Coleman Garden Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Coleman Garden Expert? Answer questions, earn points and help others
View Most Popular
Coleman Garden
  • Coleman Garden
Most Popular Question
coleman 1210 power washer no water comes
  • Garden
