20 Most Recent
Lenovo 21.5 IdeaCentre A600 2.0 GHz Intel Pentium Dual-Core All-in-One Desktop PC w/remote (30113HU) Questions & Answers
My lenovo ideacentre a600 wont
I have the same problem and still unsolved. However, I would like to notify mr. Hingee that this machine uses a dedicated mainboard (very neat I may add). Also in order to eject cd, touching the right bottom of screen will lit a menu and touhing the second one on the right will eject the cd.
IdeaCentre B300 power failure
first check if there is power failure in your locality
check if switch is on
check if UPS is working
check SMPS
if sms ok then check motherboard
could be static current in ram
2/29/2016 3:54:30 PM •
Lenovo...
Answered
on Feb 29, 2016
Touch screen not working
Verify the driver is installed for the touch screen. Go into the device manager to verify the driver.
6/16/2015 2:07:21 AM •
Lenovo...
Answered
on Jun 16, 2015
When turn pc monitor no signal
Verify all the cables are seated. You may also have a problem with your graphics hardware or drivers. If you get the BIOS screen typically signified by the manufacturer logo, press F8 to enter safe mode. If that works then it is most likely a driver issue.
6/16/2015 2:05:41 AM •
Lenovo...
Answered
on Jun 16, 2015
Web pages and programs are to large
Two possibilities: your pc's resolution is not high enough (which means you need to go to the desktop, right click anywhere in the blank area, select screen resolution, and change it to something higher) or, your browser is "zoomed". Hit ALT (the alt key) + V (for view) go to Zoom and lower the zoom factor.
I suspect the second is the problem as it's easy to zoom (ctrl+ and ctrl- will do it too).
7/18/2014 5:53:31 PM •
Lenovo...
Answered
on Jul 18, 2014
Puk code
WHERE DO I GET MY PUK CODE?
The PUK code is unique to your SIM card, so you can only get this from your mobile network.Sometimes they will give you this when you first get the SIM card, but not all networks do this. If you cannot find it, give your mobile network a call and they will be able to give you the PUK code after you have answered some security questions
3/23/2014 8:26:17 AM •
Lenovo...
Answered
on Mar 23, 2014
