20 Most Recent
Kidde 120-Volt Front Load Battery Smoke Alarm Questions & Answers
I just replaced 3
The Kidde website does have a lot of manuals but you need the model number. Try going to this URL, then browse by subject. You'll probably find the answer there.
Our hard wire smoke detector
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Our smoke alarm with battery
You didn't mention if you had replaced the battery, yet. If you haven't, then that's more than likely the problem. Also, it probably needs cleaning. You can accomplish this by using canned compressed air (like you clean your computer with). Use the straw nozzle to reach all the nooks and crannies. Clean after removing the old battery and before installing the new battery. Batteries should be changed annually and at the same time clean the unit. When using the canned compressed air, try to keep the can in the upright position, as much as possible.
My alarm and smoke detector keeps beeping a single
Ours keeps chirping even after we replaced the battery. I'm not sure how to fix it.
We are going to try and clean it but if it keeps doing it after that then I guess it means it needs to be replaced, right?
Co2 detector
Check to see if the unit has a replaceable battery. If not, you will likely find instructions on front or back that tell you exactly what the beeping means.
11/19/2014 11:00:35 PM •
Kidde Home
Answered
on Nov 19, 2014
Smoke detector keeps chirping after battery is
The chirp means the battery you chose wasn't good enough... it has to be the newest '''alkaline''' you can get hold of. If it isn't alkaline that's why you are having trouble. Upon replacement press the button to do a hard reset.
10/16/2013 2:20:53 AM •
Kidde Home
Answered
on Oct 16, 2013
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading
Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
4/24/2024 12:02:34 PM •
Home
Answered
Yesterday
