20 Most Recent
Brother MFC-5890CN All-In-One InkJet Printer Questions & Answers
Cartridge in but printer saids cannot detect reinstall slowly
I've just resolved this problem on one of these printers. There could be more than one cause - but this is worth checking. The cartridges for this machine are just ink reservoirs - there are no electrical connections to the cartridge. This is written based on my experience with the black cartridge, the sensors are repeated for each of the other cartridges so my notes should apply to all. This particular printer had been using non-Brother ink for a while - this may or may not be the cause of the problem.If you remove the black cartridge and look into the area where it came from you can see 2 black plastic arms extending horizontally out of the middle of the slot at the back. One of these contains a infra red transmitter, the other an infra red receiver. The printer knows if there is something blocking the beam between these 2 arms or not.The cartridge has a plastic bar on it which will break the beam as it is inserted. When the cartridge is fully inserted the beam looks through a transparent window in the cartridge, so the beam is broken if there is ink. If the cartridge is empty then the beam is not broken.The plastic bar which initially breaks the beam is quite small. If you insert the cartridge too fast then the beam will be broken for a very short period of time - the printer may not have time to detect this.There is also another pair of arms with infra red transmitter/receiver above the back of the cartridge which detects when it is inserted. As the printer knew the cartridge was fitted (it would otherwise display a "no cartridge fitted" alert) I knew this sensor was ok.In my situation the black ink had gummed up one side of the black arms which I originally described. This meant that the beam was always broken. The printer cannot understand this situation as it expects the beam to be intact before the cartridge is installed, then broken as the black plastic bar passes through it, then intact once the bar has passed, then broken by the full ink cartridge. If this sequence is not seen then the printer displays an error.To fix this - try cleaning the inside face of the arms. The transmitter/receiver are in a slightly indented area about 2mm square. I suggest IPA (Isopropyl alcohol/rubbing alcohol) on the end of a cotton bud.In my case the ink was too heavily gummed, so I dismantled the printer, removed the circuit board behind the cartridges containing the sensors for the 4 cartridges and continued cleaning using a pin to carefully scratch the dried ink off. Take care not to scratch through the plastic window over the transmitter/receiver. Note, the control panel and the entire upper section of the printer needs to be removed in order to reach the back of the cartridge bay.Please take proper precautions if you need to dismantle the printer. It contains delicate mechanical and electronic parts, and obviously has mains power entering. I take no responsibility for your safety or the continued operation of the printer. If in doubt, take to someone who can repair it and provide this information to help with their troubleshooting.Once the printer was reassembled, I powered it up and slowly inserted the black cartridge, at which point it went through the usual process of asking if it had been changed, before showing the 4 inks as being full.Good luck!Darren - ex-electronics repair engineer
2/14/2013 12:01:26 PM •
Brother...
Answered
on Feb 14, 2013
My black ink is not working
Blocked print head nozzles Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles. Try the printer maintenance to clear the printer nozzles. After several deep cleaning attempts and there is no improvements in the print then a new print head is required. A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
10/24/2012 9:19:45 AM •
Brother...
Answered
on Oct 24, 2012
I lost my disk and need info to put in new computer
Visit the Brother Solution Center for your country/area of residence and download the Brother software suite relevant to your machine: Model number, Operating system (Windows, or linux, 32 or 63 bits) and install it on your computer. You must choose the type of connection (USB or LAN). Install the USB or NEtwork software. After installation, connect the printer (through a USB cable if you chose USB installation, or ethernet cable if you chose Network. then connect the MFC.For the scanning software (ScanSoft) you will have to install it from the original CD. If you no longer have it you can buy some scanning software or install free software from the web. Several applications (Word, Acrobat) can scan by themselves. You also have some free OCR software; FreeOCR, PaperScan Free, etc.
7/31/2012 4:34:53 AM •
Brother...
Answered
on Jul 31, 2012
