20 Most Recent
Giorgio Armani Armani Automatic AR4211 Watch Questions & Answers
How does the moonphase work?
moi aussi j ai achete une montre armani, mais le probleme c est qu elle ne fonctionne pas quand il sonne 16h30 p.m, avez vous une idee, merci de me repondre.
After replacing battery can't get the backplate of AR0156 back.
If you cannot snap the back on with your fingers the only safe way to get the back on again is to use a watch press. This is an expensive tool that most jewelers will have. I strongly recommend you take it to a jeweler (may want to call first to make sure their company will do it because most chain stores will not work on most brands). They should not charge you.If you are determined to do it yourself then you can try wrapping a wide pliers with duct tape or cloth and applying pressure on the front and back of watch to pop it on. WARNING: this is very dangerous for your watch. DO NOT apply pressure to the crystal, try to put the pressure on the stell lugs instead...
