20 Most Recent
Giorgio Armani Emporio Armani Sport Ar0532 Watch Questions & Answers
HOW TO RESET STOP WATCH TO ZERO
What you need to do is to pull the crown to step 2 (full out) and then push the start button. Then the second hand will start moving one tick a time all through the dial. Keep pushing it until you reach to zero.then push crown back in, That's it.
How to set the year for armani meccanico watch
The Armani site is not very helpful but try this one:-
The year should change when the month hand passes from December to January.
If you pull out the winder (it may need to be screwed out anticlockwise first), you should be able to find a position where the month can be changed. Wind the month hand passed December. If you need to advance it more than one year, then wind it backwards from January to December and then forwards again to January.
Where can I buy the original strap?
All the info you should be able to find here:
www.emporioarmaniwatches.com
You can email, get customer support, call by phone or place an order.
Don't forget to rate, please.
Emporio Armani AR0532 Sports Watch with rubber/plastic strap
Here is a link to Emporio Armani Watches (paste it into your browser):
store.emporioarmaniwatches.com/products/H45820.jsp -
CachedClick on your model, then click on Customer Care tab. Here you can send an email or even contact online or by phone and get your strap sorted.
I have a Emporio Armani
Depending on where you are located... Samuels Jewelers or Some Macey's (Lazurus's) carry Straps for higher end watches. If nothing else go to either Amazon.com or 111watches.com to order what you need there.
After replacing battery can't get the backplate of AR0156 back.
If you cannot snap the back on with your fingers the only safe way to get the back on again is to use a watch press. This is an expensive tool that most jewelers will have. I strongly recommend you take it to a jeweler (may want to call first to make sure their company will do it because most chain stores will not work on most brands). They should not charge you.If you are determined to do it yourself then you can try wrapping a wide pliers with duct tape or cloth and applying pressure on the front and back of watch to pop it on. WARNING: this is very dangerous for your watch. DO NOT apply pressure to the crystal, try to put the pressure on the stell lugs instead...
