20 Most Recent
Bernina Virtuosa 150 Questions & Answers
I have a Bernina virtuosa
Never been serviced? Whoops, as an old tech, I'm not surprised, how often do you oil your machine and is it with quality Bernina oil or a light synthetic oil?
Have you checked the bobbin case tension? As you are using two types of thread there will always be some imbalance of tensions best when you are turning corners to slow down your movement that will help a bit, but you may have to tighten bottom tension
also another hint would be to use a Metallica or topstitching needle with a larger eye, allowing the upper thread to move more freely as the thread forms the stitches.
if you need further help
wayne Buss
[email protected]
How do you adjust the foot pressure
There is a dial on the left side near the light that can be rotated to put more pressure or less pressure on the foot. If that is not working the spring inside may have become detached
How to adjust bobbin tension bernina 150
On the side of the bobbin case is a half moon shaped curved spring with a screw through it securing it to the bobbin case
take the small yellow or red screwdriver that came with your machine and turn the screw clock wise to tighten and counter clockwise to loosen. Correct tension is achieved by inserting a full bobbin of thread, into bobbin case, remove the half moon shaped shuttle from machine, put the bobbin case on to the shuttle, now hold just thread and with a youo motion shake the above and the shuttle and bobbin case should slide down the thread about 12 to 24 inches for correct tension
Where is the light switch fo light
NEwer machines do not have a light switch, the light bulb on your machine may need replacement.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Why is it that as soon as I plug in the foot pedal the machine starts?
The foot control is a simple device with a resistance value that, as the foot control is depressed, the value diminishes and the machine runs faster. The cause of an immediate run condition will be the result of the following:
1. The cable or plug has been damaged so as to connect both wires to create a maximum run state. 2. Most common to the foot control itself is that the actuator for the slide resistor is broken and stuck in the max run spot as well as having been disconnected from the on/off micro switch. 3. The foot control has been taken apart and improperly assembled.
SewTechnical Home
