20 Most Recent Ebel Sportwave Gent 100m Water Resistant Case Two Tone Steel and 18k Gold Watch for Men Questions & Answers
How to replace a battery on a ebel watch?
The most water resistant watches will have a screwed down case back and crown for maximum water resistance, both of which are backed by internal gaskets. These are the types this articlde will concentrate on. To change the battery in a water resistant watch you will need:
  • Adjustable case tool
  • Case holder ' + google_ads[0].line1 + ' ' + google_ads[0].line2 + ' ' + google_ads[0].line3 + ' ' + google_ads[0].visible_url + '' + ' Ads by Google'; } else if (google_ads.length > 1) { s += 'Ads by Google'; for(i = 0; i ' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + ' ' + google_ads[i].visible_url + ''; } s += ''; } document.write(s); return; } google_ad_client = 'pub-8735055091446807'; google_ad_channel = '5953492595'; google_ad_output = 'js'; google_max_num_ads = '2'; google_ad_type = 'text_html'; //google_image_size = '468x55'; google_feedback = 'off'; // --> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
  • Small screw driver
  • Polishing cloth
  • Cotton gloves
  • Small tweezers
  • Plastic tweezers
  • Soft clean cloths
  • Battery tester
  • Paper cup
  1. Place the watch in case holder. Place the watch in the case holder, if you have one. If you do not, place it on a soft cloth.
  2. Check for room to work. Check to see if there is room to attach the adjustable case wrench and rotate it 360 degrees. If not remove watch band.
  3. Remove case back. Fit the adjustable case wrench into the slots on the case back. Tighten it down until it is snug. Be careful not to slip with this tool as it can scratch the case back of your watch. Work slowly. When it is unscrewed gently pry up the case back taking great care not to damage the internal gasket. If the gasket gets damaged it will need to be replaced with the battery to retain water resistance.
  4. Remove battery. The battery will be held in place by some type of retention device. It will need to be removed. Some clips will be removed by using tweezers. Some clips may be moved using a screw driver, and some simply bend out of the way slightly. Remember how it was removed as it must be put back in place exactly for the circuit to be completed after battery change. If the clip is removed, place it and any screws in a paper cup to prevent loss. Remember how the battery was seated, plus (positive) side up or down etc. it needs to be replaced correctly to work.
  5. Test battery. Using the battery tester check the battery. If it is dead move to next step, if it is not take the watch to a jewelers for inspection.
  6. Clean and inspect battery box. Inspect the battery box the battery came out of. If there is corrosion take it to jewelers for inspection. If there is light dust it may be cleaned with a clean soft cloth.
  7. Buy battery. Use the numbers on the battery and buy a new one. Occasionally the number will be obsolete and you will be referenced to a replacement battery in the battery charts. This is the time to also replace the gasket if you need to. Check with a watch maker or jeweler, or the watch company to buy a replacement. We cannot stress enough how important this gasket is to a water resistant watch, without its integrity your fine watch may no longer be resistant.
  8. Replace battery. Using the plastic tweezers if you have them, or fingers wearing cotton gloves, replace the battery. Never use bare fingers as finger oils may corrode or short out the new battery. Carefully replace the retention device as it was remove.
  9. Replace case back. Make sure that the gasket is in place, and not pinched or caught in the case back when you set it in place. Screw down the case back using your fingers until it is tight and needs the case wrench. Attach case wrench as before and tighten down the case back.
  10. Reset and clean watch. Using the appropriate method reset the watch. Use the polishing cloth to clean off any dirt and finger prints.
OR...take to your local jeweler/watchmaker who has the appropiate tools and let them do it for you!!!! :)
8/11/2010 3:41:23 AM • Ebel Sportwave... • Answered on Aug 11, 2010
2answers
Watch links for gents ebel sportswave.
Hi, I have two links for an Ebel Sportswave watch. They were taken out of the bracelet of my 6-year-old Ebel and are like the ones shown in your photograph. Let me know if you are still interested and if you are, make me an offer.
Thanks.
9/24/2009 7:40:02 AM • Ebel Sportwave... • Answered on Sep 24, 2009
2answers
I need to change a battery on an Ebel Beluga. I took the screws off of the back, but I don't see a notch to fit a case tool into. How can i get the back open? TIA!:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjUr5fpzKODAxWrrYkEHUk5CRkQtwJ6BAgXEAI&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DNsO51niRkG4&usg=AOvVaw3cAlt5v_VcYq2mMw1bFCuo&opi=89978449
12/22/2023 7:00:00 PM • Ebel Watches • Answered on Dec 22, 2023
Change men's ebel watch battery
This is for a woman's watch but may apply to yours. You need to remove the screws around the bezel of the front of the watch (not accessed through the rear like most watches).Be sure to use the correct size screwdriver to avoid marring the screws. Then you will need to remove the half of the split stem attached to the crown. Remove the movement from the front, replace the cell, lube the gaskets, and reassemble.This has been asked before. Here is that answer:www.fixya.com/support/t1684765-ebel_wave_ladies_watch_battery
3/26/2017 5:28:53 PM • Ebel Watches • Answered on Mar 26, 2017
Need to locate screws that hold band onto the case
May I get the make and model # of the watch to help you more.
11/20/2011 12:08:24 AM • Ebel Watches • Answered on Nov 20, 2011
2answers
Have an Ebel Men's Watch:
The really nice thing about your watch is that when you need a battery, the watch gives you a 30 day notice by having the second hand do what I call " a triple step" where the watch keeps time, but youe second hand goes 3-4 steps real fast and then stops. Please take your watch to a reputable watch repairman, because your watch has a Cartier movement , and NOBODY but Cartier has the parts for your watch if somebody who dosn.t know what they are doing messes it up. If you have anymore problems feel free to ask me anytime . I LOVE EBELS!!!!
11/2/2011 2:37:15 PM • Ebel Watches • Answered on Nov 02, 2011
My crystal cracked a couple
the crystal is not properly attached it may have tiny opening where moisture goes inside. you have to bring it to watch service center immediately to avoid much bigger problem. i hope i had been helped you.
9/6/2011 4:20:21 PM • Ebel Watches • Answered on Sep 06, 2011
0answers
I have a Versace (Madison)
You can only get the push button only in the Ebel swiss service centre.You cant buy it online.Since it is very costly watch you have to buy the original parts in their service centre.
Contact them ask for your local service centre address.
http://www.ebel.com/#/en/contact-us
Store locator in your area:
http://www.ebel.com/#/en/Store-locator
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
9/11/2010 3:19:19 AM • Ebel Watches • Answered on Sep 11, 2010
How does the leather strap
It is fastened by a deployment-buckle clasp.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
2/3/2010 8:15:23 AM • Ebel Watches • Answered on Feb 03, 2010
Ebel Sportwave Gent 100m Water Resistant Case Two Tone Steel and 18k Gold Watch for Men Logo
5 questions posted
Top Ebel Watches Experts
ADMIN Andrew
ADMIN Andrew
Aron
David Kassin
David Kassin
Are you an Ebel Watch Expert? Answer questions, earn points and help others
View Most Popular
Ebel Watches
  • Ebel Watches
Most Popular Question
watch links gents ebel sportswave
  • Watches
