20 Most Recent
Grundig 15 in. LCD TV/DVD Combo Questions & Answers
How do I tune a Grundig TV/DVD with no remote? Is it a combination of buttons on the front panel? Thanks
Get a pen and a piece of paper.
If I remember correctly, each button has a bizarre symbol next to it.
Draw the buttons on the paper and draw the symbol that appears beside each button.
With the TV on, press the first button and note what it does. Press it a second time to see if that progresses to something further or cancels the operation.
Repeat this for the other buttons.
I seem to remember a vertical green line appearing on Grundig sets which indicated that the tuning was activated. Look for buttons such as > or >> or < or << that suggest scanning for channels. Make sure you can pick up analogue TV signals in your area.
It also helps if you have a VCR or DVD recorder which is already tuned and you can tune the TV to that signal.
Can not fine code for remote control for
look in your user manual for the remote your using and find out how to search for the code,most remotes have a feature that allows you to search for the code by pressing a button over and over until the device shuts off.hope this helps
How do I eject a dvd?
I don't have the same TV but on my tv there are 3 buttons on the left hand side of the TV above where the DVD is inserted. Try to press the top button as this should eject the DVD.
Hi iam looking for a power plug for my grundig
Chances are that the plug is somewhat universal. RadioShack sells all different kinds of power plugs, just remember the shape of the plug that goes in the back of the TV and you should be good to go. Also, they are relatively cheap so you won't be breaking the bank on it. If RadioShack for some rare reason doesn't have it, Best Buy should.
Good luck and please rate my solution accordingly.
Respectfully,
Don
Keeps turning itself on
some tv's have an "alarm clock" check if that is turned on? if it is your tv's will always turn on at the same time.
Hello !! Friends i need to know how to remove key lock from grundig tv model gu26dvd. .with out using a remote control. Thanks
Hello! I'd be happy to help you.
To remove the key lock from your Grundig TV model GU26DVD without a remote control, you can try the following steps:
- Turn on the TV using the power button on the TV itself.
- Press and hold the MENU button on the TV for several seconds until the menu appears.
- Use the volume up/down buttons to navigate to the "Lock" or "Child Lock" option and press the MENU button to select it.
- Enter the four-digit password using the number buttons on the TV. If you don't know the password, you may be able to find it in the TV manual or by contacting the manufacturer.
- Navigate to the "Off" option and press the MENU button to select it.
- Press the MENU button to exit the menu.
If the above steps don't work or you don't have the manual to find the password, you may need to contact the manufacturer or a professional technician for assistance.
3/4/2023 7:25:58 AM •
Grundig...
Answered
on Mar 04, 2023
How to change or reset pin code on Grundig TV 32 GEH 6600B
Hello Petar,
To reset the pin code on your Grundig TV 32 GEH 6600B, you can try the following steps:
- Turn on your TV and press the "Menu" button on your remote control.
- Navigate to "Settings" and then select "Child lock" or "Parental control."
- Enter the current pin code (if you know it) using the number buttons on your remote control. If you don't know the pin code, try entering "0000" or "1234".
- Once you are in the parental control menu, select "Reset" or "Clear all" to reset the pin code.
- Confirm that you want to reset the pin code by entering "Yes" or pressing the OK button on your remote control.
If this does not work, you may need to consult the user manual for your specific TV model or contact the manufacturer for further assistance.
I hope this helps!
3/4/2023 7:22:39 AM •
Grundig...
Answered
on Mar 04, 2023
GRUNDIG 50 vle 932 bh won't boot
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://elektrotricks.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name of your set, in its search box at the right column. View it on a desktop or in web View by mobile. Mobile view has no search box.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location...
9/15/2021 10:57:26 AM •
Grundig...
Answered
on Sep 15, 2021
