20 Most Recent
Grundig GU22DVDPX 22 in. LCD TV Questions & Answers
How do you change the input without the tv remote?
I don't have a grundig tv, but most tvs have the buttons to change input / channel /volume ect. hidden, normally at the back along one edge, but some times along the bottom. My LG has them on the right hand side when looking from the front. Hope this helps.
10/28/2015 9:20:17 PM •
Grundig...
Answered
on Oct 28, 2015
Have grundig gu22dvd tv and can not get volume on the sky remote have tried the normal things and have code but still doesn't work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
- Press the TV button on the Sky remote
- Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
- Key in 9, 9, 0
- Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
- Repeat for 2 and 3
- Note: no Blink = 0 (zero)
9/10/2014 1:29:47 PM •
Grundig...
Answered
on Sep 10, 2014
The sky remote will not operate the volume on my grundig gu22dvd have tried all the usual things codes etc but still doesnt work
1.
press tv
2.
- Key in 9, 9, 0
9/10/2014 1:29:01 PM •
Grundig...
Answered
on Sep 10, 2014
Remote not working as i moved tv into another room
If the remote control you've bought is a universal remote control, you have to set it with your TV, by TVs setup codes. The setup code list will be attached to the new remote controls' packing.
If you wish to get more details, check the sites linked
here.
Set-up code list, and Set-up
procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic
/ Timeslide, can be selected by the drop-down list, by the top left
of the display window, will make surf easy
11/6/2013 7:03:07 AM •
Grundig...
Answered
on Nov 06, 2013
