20 Most Recent
Grundig GU26DVD 26 in. LCD TV/DVD Combo Questions & Answers
Gu26dvd remote doesn`t work batteries ok
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
How to display gu26dvd service menu?
may have to purchase service manual, but if you do attempt this Understand that if you're not sure what you are attempting you can cause the unit to not work at all.
How to display gu22dvd service menu?
If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
A line has appeared across the bottom of the
If your TV is still under guarantee then change it asap, if not you have a problem, the panel has failed, in very rare cases the lines will disappear when the set is at its maximum operating temperature, that said it will never be 100% again, sorry
Hello !! Friends i need to know how to remove key lock from grundig tv model gu26dvd. .with out using a remote control. Thanks
Hello! I'd be happy to help you.
To remove the key lock from your Grundig TV model GU26DVD without a remote control, you can try the following steps:
- Turn on the TV using the power button on the TV itself.
- Press and hold the MENU button on the TV for several seconds until the menu appears.
- Use the volume up/down buttons to navigate to the "Lock" or "Child Lock" option and press the MENU button to select it.
- Enter the four-digit password using the number buttons on the TV. If you don't know the password, you may be able to find it in the TV manual or by contacting the manufacturer.
- Navigate to the "Off" option and press the MENU button to select it.
- Press the MENU button to exit the menu.
If the above steps don't work or you don't have the manual to find the password, you may need to contact the manufacturer or a professional technician for assistance.
3/4/2023 7:25:58 AM •
Grundig...
Answered
on Mar 04, 2023
How to change or reset pin code on Grundig TV 32 GEH 6600B
Hello Petar,
To reset the pin code on your Grundig TV 32 GEH 6600B, you can try the following steps:
- Turn on your TV and press the "Menu" button on your remote control.
- Navigate to "Settings" and then select "Child lock" or "Parental control."
- Enter the current pin code (if you know it) using the number buttons on your remote control. If you don't know the pin code, try entering "0000" or "1234".
- Once you are in the parental control menu, select "Reset" or "Clear all" to reset the pin code.
- Confirm that you want to reset the pin code by entering "Yes" or pressing the OK button on your remote control.
If this does not work, you may need to consult the user manual for your specific TV model or contact the manufacturer for further assistance.
I hope this helps!
3/4/2023 7:22:39 AM •
Grundig...
Answered
on Mar 04, 2023
