20 Most Recent Dell Inspiron 1721 Notebook Questions & Answers
2answers
I want to restore my dell inspirion 1721 to factory settings i try the f8 key option but in the advanced boot options there is no "repair your computer" option. what can or should i do?
Your laptop should of come with a disc to restore it back to the factory setting what windows are you running?There should be a restore point you can go back to
6/28/2014 10:32:48 PM • Dell Inspiron... • Answered on Jun 28, 2014
I just purchased a Dell Inspiron 17 700 series for my husband to take for work in Africa. Where he is at he has to use an internet stick and the computer will not recognize the stick. Please if anybod
Please let me know the exact model of this stick. Also, the installed operating system in this Dell Inspiron 17-700.
3/11/2014 4:57:31 AM • Dell Inspiron... • Answered on Mar 11, 2014
Will a lp171wo2 fit a dell 1721
yes this should work fine
3/2/2014 8:15:28 PM • Dell Inspiron... • Answered on Mar 02, 2014
Dell laptop 1721 saying warning something wrong with hardware
what does the error say for me tobe able to help you
3/2/2014 8:12:29 PM • Dell Inspiron... • Answered on Mar 02, 2014
I am locked out of my dell 1721 by the system/bios password!!
normally on a dell u have to have the power charger plugged in and hold the fn key bottom left and use the arrow keys to make it brighter. however it could be your screen or inverter that maybe faulty. the link below charges 60 pounds for inverter fix which contols the brightness and 100 pounds if it is the screen. now for the bios password the only way you will be able to remove this is the strip the system down and remove the cmos battery for few mins with no power and put back this should reset it again the company can help you with this if needed. laptop repair london computer repair service no fix no fee
3/2/2014 8:11:40 PM • Dell Inspiron... • Answered on Mar 02, 2014
My dell inspiron 1721 notebook display is dark on the right side and bright on the lefth side
sounds like u need replace the screen on the laptop. i am based in london and have used the company below cost 100 pounds includes fitting and if it wasnt that which i would be very surprised they wouldnt charge you or search the screen up on ebay. hope this helps Help my laptop keyboard is broken
3/2/2014 8:06:24 PM • Dell Inspiron... • Answered on Mar 02, 2014
2answers
Screen doubled
It seems the GPU is dying. It is cheaper to buy a laptop replacement than to fix this problem.
3/2/2014 8:03:15 PM • Dell Inspiron... • Answered on Mar 02, 2014
Just the letter and number caps lock light flashes scroll lock light stays solid blue
Hi Robert Harper, It looks like an issue with Video (BIOS, Memory Shadowing) Could you provide me with the Service Tag of the system? You can try connecting external Monitor if available to check if that works? (After connecting external monitor you need to press fn+f8 to toggle the display)
2/21/2014 5:47:53 AM • Dell Inspiron... • Answered on Feb 21, 2014
I cant access my webcam on my dell inspiron 1721 , what am i suppose to click on to open my webcam up??
Usually computers that have built in webcams come with a software suite for photos, unless Windows has been wiped an re-installed. I would check the Dell website with the service tag in order to see a list of programs/drivers that were installed when the computer was brand new. Let the site search your service tag for you. You should be able to download the programs needed right there.
9/19/2013 6:04:55 PM • Dell Inspiron... • Answered on Sep 19, 2013
2answers
Dell inspiron 1721 hard drive not recognized for Vista reinstall
ok, theres a small issue with the raid controller. You have to install a 3rd party raid driver (its on the dell cd) to continue, OR, you can set that BIOS's hard drive controls to ATA or LEGACY (legacy would likely work best, but youd have no 'raid' functions, but who sets up raid drives on a notebook?). Your last option is use the dell discs to restore, and inssert the windws disc when prompted
9/19/2013 5:58:19 PM • Dell Inspiron... • Answered on Sep 19, 2013
How to start computer on external monitor
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 ASUS and Dell = Fn + F8
5/10/2013 1:37:16 PM • Dell Inspiron... • Answered on May 10, 2013
Start directly on external monitor
Connecting an External Monitor or Data Projector
5/10/2013 1:36:51 PM • Dell Inspiron... • Answered on May 10, 2013
How do i switch on wireless
there is a button on your laptop that will turn on your wireless. An led will come on and you will see a confirmation on the bottom right once it sees a wireless signal. the next part is to figure out if you have the security enable on your wireless router and if you do know what the SSID and the KEY for it. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
2/10/2013 10:39:35 AM • Dell Inspiron... • Answered on Feb 10, 2013
How do i turn on wireless
i don't know about dells set up But normally on the front panel there should be a slide swich to turn on the wireless connection if this fails contact dell
2/9/2013 1:12:19 PM • Dell Inspiron... • Answered on Feb 09, 2013
What is the system password for dell xps m140
Try four zeros (0000) or password (password).
1/16/2013 4:28:56 PM • Dell Inspiron... • Answered on Jan 16, 2013
Change inspiron 1721 lid
Do you mean the LCD screen with the lid?If so you undo the hinges and disconnect the video and power leads to the inverter.This WEB site shows how to remove the screen/hinges.Replacing Display hingeshttp://www.laptopparts101.com/display-screen-hinges/
4/28/2012 10:16:23 AM • Dell Inspiron... • Answered on Apr 28, 2012
I just purchased a dell inspiron 1721 and I can't get it to connect to my wireless network
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
3/25/2012 10:45:29 AM • Dell Inspiron... • Answered on Mar 25, 2012
2answers
My Drive is not reading any CD I put in it
Optical drive problems
NOTE: High-speed optical drive vibration is normal and may cause noise, which
does not indicate a defect in the drive or the media.
NOTE: Because of different regions worldwide and different disc formats, not all
DVD titles work in all DVD drives.
Problems writing to a CD-RW or DVD+/-RW
CLOSE OTHER PROGRAMS - CD-RW and DVD+/-RW drives must receive a
steady stream of data when writing. If the stream is interrupted, an error
occurs. Try closing all programs before you write to the drive.
refer to the manual , click this link http://support.dell.com/support/edocs/systems/ins1721/en/om_en/pdf/GU051A03MR.pdf
3/6/2012 11:27:52 PM • Dell Inspiron... • Answered on Mar 06, 2012
Dell Inspiron 1721 Notebook Logo
Popular Tags
70 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
screen doubled
  • Computers & Internet
