20 Most Recent
HP Deskjet D1560 InkJet Printer Questions & Answers
Help! My HP deskjet D1560 printer is
Firstly turn the printer off and leave it off for a few mins. This should clear the buffer.
If not then can delete the printer "from control panel", restart PC and then re-install the printer....but make sure you have/can get the driver for the printer first!
Can an ink cartridgefrom rapid refill cause
Hello.
Sometimes if the cartridge was completely empty then a refill might not work, also there is no way of re-setting the ink levels unless you swap it over 4 times with other cartridges (there is a 3 cartridge memory so on the 4th cartridge change, you can use the 1st one and it will read as new)
Try this link as a way of unblocking print heads and assisting in getting the ink to flow again.
http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps
Regards
GM
My hp d1560 keeps blinking
HI there.
The first thing you can is to open the cover and remove the ink head.Then clean their contacts and the ink head carrier of any ink on them.Then turn on/off and try again.
My Hp Deskjet d1560. is
Uninstall and Reinstall the software, Most of the tie it works.
To Download:
1 Go to hp.com
2 Click on Support and Drivers
3 Enter your product name or number, in this case just type in Officejet 8500 All-In-One
4 Hit go
5 Choose your operating system
6 Hit Next
7 Click on the link that says Driver - Product Installation Software
8 Save it to your desktop
A driver des not opend
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3374275&
My hp deskjet printer light
make sure there is no paper jam inside and all the catridegwes are proper and not dry.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
08777234545
Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:
The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (
Figure 2: Example USB connection (your product might not look exactly the same as this example)
Remove the cartridges from the product.
Wait for the 'Insert Cartridges
' message to display on the control panel.
Disconnect the power cord from the back of the product.
Wait 60 seconds.
Reconnect the power cord. If the product does not automatically turn on, press the Power button (
Reinsert the cartridges, and then close any open doors on the product.
If you receive a prompt to print a calibration page, do so.
Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
INSTALACION
Click here
Click on above link select your os then download driver.
Then you can install your printer's driver.
Let me know if you need further assistance.
Thanks for using FixYa.
Printers hp1560 drivers does not
Hi, unfortunately HP does not provide a driver for Windows Server 2003. Your only options for installing this printer is to try one of the
other drivers (such as XP or Vista), or finding a similar printer that does support Server 2003 and using that driver instead. Since most drivers use the PCL language, you may be able to get away with using another printer's driver (though you may lose some functionality).
How reset hp deskjet cartridge
There is no chip in hp21 or hp21 cartridges. kindly state your'e problem with the printer
pls. vote for better service... thank you
