20 Most Recent Toshiba Satellite A205-S5855 Notebook Questions & Answers
My Toshiba laptop suddenly shuts
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution: If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
I decided to use a shop vac to suck the dust out and it worked. I tested it by letting the machine run all night and it worked. It's been a couple of weeks now and I'm glad I did it. I was ready to take the machine apart, now I'm glad I didn't. I'd suggest you use a heavy duty shop vac to clean out the fan and heat sinks first.I agree. Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner. If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you. Toshiba Satellite A15 Clogged Heatsink Toshiba Satellite A35 Clogged Heatsink Toshiba Satellite P15 Clogged Heatsink.
8/25/2017 5:32:32 PM • Toshiba... • Answered on Aug 25, 2017
Toshiba a205-s5806 not charging batt bt powering mainboard
hmmm try these two optionsfirst take out battery completely and see if puter runs on adapterthen put battery in and see if it runs on batteryif 1 works and 2 does not battery is ready for replacement(usually after 2 years)
5/24/2012 7:44:11 PM • Toshiba... • Answered on May 24, 2012
I installed vista ultimate 64
== Easier way ==
DIRECT LINK TO DOWNLOAD
(It's a Windows 7 64-bit driver, but it will work too)
(Vista & 7 uses the same driver)
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_wifi_atheros_TC00190600E.exe
Download and install the driver
== Harder way ==
* Your driver can be found at THIS LINK
* Select Windows 7 64bit from the 1st drop-down menu.
(I've you select Vista, you wont find this driver)
* Select WiFi from the 2nd drop-down menu.
* Download and install the driver
Atheros Wireless LAN Driver for Windows 7 (32/64)
FEEL FREE TO ASK ME FOR HELP !
6/26/2011 10:44:55 AM • Toshiba... • Answered on Jun 26, 2011
2answers
All soft ware driver in
You can download any orall the Windows device drivers for your model laptop from the Toshiba WEB sitefrom their download page. Make sure you enter the model of your laptop so youcan get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
5/23/2011 9:30:59 AM • Toshiba... • Answered on May 23, 2011
Dear Tohiba We doing used
Go to the product site.
1.Click on Download.
2.Choose Category as Laptops.
3.Choose family as Satellite.
4.Now choose your model and click on Go button.
5.It will Display all the driver.
Thanks for using FixYa.
5/17/2011 7:51:27 AM • Toshiba... • Answered on May 17, 2011
I want to reformat my
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1998596&rpn=PSAE3U&modelFilter=A205-S5855&selCategory=2756709&selFamily=1073768663
This is the official Toshiba page for your laptop. It should have every driver you'll need for your reformat, make sure you get the right operating system though. Hope this helps!
4/11/2011 5:27:47 AM • Toshiba... • Answered on Apr 11, 2011
How do i fix my
You'll need to get an desk lamp of some sort to light your face.
What is happening is that your face is being lit by your computer monitor, which will give it a purple cast to it.
Find a nice, bright soft-white desk lamp to place to the side of your computer screen and that should be enough to prevent the purple face.
1/22/2011 1:02:29 AM • Toshiba... • Answered on Jan 22, 2011
Laptop shuts down without warning on battery or
CHECK YOUR POWER SUPPLY,THE POWER CABLE AND THE BATTERY AND POST BACK.
12/8/2010 3:00:36 AM • Toshiba... • Answered on Dec 08, 2010
3answers
I want to install Windows XP SP2 on my toshiba
OK ...this is happening cause of a feature called ahci enabled in bios for the sata HDD ..this have to be disabled in order to be able to find the hard disk without the AHCI driver installed like a 3rd party (To do that just go to bios by pressing F2 on start immediately after first screen lights up ...and in Bios ..go to advanced..or devices..it sthe second or the 3rd option ...and in there look for the sector where th rdrives are detected..the HDD and teh cd drive ..in there you will find when you choose the HDD the AHCI function ..and you have to disable it ...than press F10 to save the changes..and it will work ..
the drivers you need are available on the support site ..
9/4/2010 12:02:07 AM • Toshiba... • Answered on Sep 04, 2010
My laptop has a white screen and i am in iraq.
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
armania50
1/3/2010 5:37:09 PM • Toshiba... • Answered on Jan 03, 2010
Looking for toshiba a205-s5855 service manual
Here is the manual downaload it.
http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su1976824/SatA200_GMAD00173010_08Feb15.pdf
Paste this in your Web browser or in your Download Manager and Download it.
Open it with Adode Reader or Foxit Reader.
You can even print out and keep it as for your future reference.
1/3/2010 5:33:08 PM • Toshiba... • Answered on Jan 03, 2010
I need to update bluetooth
You can find the software on the Toshiba wesite
11/9/2009 7:23:56 AM • Toshiba... • Answered on Nov 09, 2009
0answers
APPCRASH
Be the first to answer 7/8/2009 10:45:42 AM • Toshiba... • Posted on Jul 08, 2009Be the first to answer
I want to install dispaly driver on windows XP i
Hey
Download the correct display drivers from this website.
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp
5/5/2009 4:26:00 AM • Toshiba... • Answered on May 05, 2009
I want to install ATI display driver for windows XP on it
Hey,
Drivers from ati website don't work.
Thanks and good luck.
Ekse
5/5/2009 4:16:39 AM • Toshiba... • Answered on May 05, 2009
3answers
Is the product key for Microsoft office 2013 the same as all product keys for 2013 Microsoft offices that operate under laptops using windows 8.1?
The product key is associated with the MS Office 2013 software, not the specific MS Windows version of Operating System - unless the MS Office lists a minimum version of OS ie: "Windows 8.0" In this case, it would not install on Windows 7. Otherwise, you should be able to install it on Windows 7, Windows 8, or later.
2/15/2024 4:30:57 PM • Toshiba... • Answered on Feb 15, 2024
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM • Toshiba... • Answered on May 22, 2023
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE a665-S6080
In BIOS, I made Pointing Device Enable and It has been done.
11/28/2022 9:05:08 AM • Toshiba... • Answered on Nov 28, 2022
Toshiba Satellite A205-S5855 Notebook Logo
25 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
  • Computers & Internet
