20 Most Recent
Universal 8-in-1 Remote Control, Touch Screen Tablet style Questions & Answers
Code for SHINELC TV using TV - 706E universal TV remote?
Please reach out to the remote manufacturer or the seller you purchased the remote from to get the list of codes necessary to set your remote to your shinelc tv. Usually each tv has multiple codes that you would need to test before you find the correct one for your brand/model of tv.
Thank you.
4/17/2024 5:31:43 PM •
Universal...
Answered
on Apr 17, 2024
How to get a universal remote to work with laserdisc and dvd player
[DENON]
[Laserdisc]
[+] LA-210 / RC-522
[+] LA-3500 / RC-520
LA-3100 / RC-517
[+] LA-3000 / RC-502
and
https://www.remotecentral.com/cgi-bin/codes/denon/
Memorex DVD universal remote control codes (3, 4 and 5 ...
eliztech.com
https://www.eliztech.com > remotes > codelists > memore...
Universal remote codes for Memorex DVDs - 3 digit, 4 digit and 5 digit codes.
Memorex DVD Remote Control Codes
DirecTutor
https://www.directutor.com > content > memorex-dvd-r...
Memorex DVD 4 Digit Remote Control Codes2003242407221297.
codesforuniversalremotes.com
https://codesforuniversalremotes.com > memorex-dvd-re...
Aug 8, 2016 - Try Memorex VCR codes 0035, 0037, 0039, 0047, 0000, 0240, 0048, 0104, 0046, 0162, 0072, and 0209. -CUR ...
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
3/11/2024 10:22:33 PM •
Universal...
Answered
on Mar 11, 2024
I have a Veon TV with a built in DVD player. I have put a DVD in and now have no way to eject it. The universal remote I use has no eject button and neither does the TV.
If you are not sure about trying any of this Get a TV specialist to look at the TV.
Some DVD players are fitted with an emergency release. Look carefully at the area around where the DVD slots into the player for a small round hole. If there is a hole there you can use a paper clip to eject the Disc.
Try this... Bend one end of the paper clip outwards. GENTLY push the bent out end into the round hole. It won't go in very far, This should eject the DVD.
If there is no hole it gets more difficult.
**DO NOT put anything metal in the slot! Household voltages can and will Kill you!**
Try this... Find a CD or a DVD you don't need anymore as you will scratch it doing this. Grip your spare disc firmly and start to Gently slide it into the DVD slot. When it gets to the position where it starts to grips and load the disc, Firmly pull the disc back out of the player.
This should trigger the load/eject motor. Because you pulled the spare disc out it should create a load error and it should eject the DVD that is already inside the player.
If this doesn't work Get a TV specialist to fix it for you.
1/30/2024 5:51:19 AM •
Universal...
Answered
on Jan 30, 2024
