20 Most Recent Universal MX-900 Remote Control Questions & Answers
You will have to go to universalremote.com and use the Contact Us (top right of webpage). Fill out the form and tell them that you need the editor software. They will have you fax them a form with your remote serial number and some other information and then they will provide you will a link to download the editor software.
Universal MX-900... | Answered on May 18, 2017
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
Universal MX-900... | Answered on Feb 03, 2017
Try by set the remote control with an other code said for your device.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Universal MX-900... | Answered on Feb 02, 2016
There should be short circuited component/s inside the remote control. It will be good to buy a new one, rather than try to repair this remote control.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Universal MX-900... | Answered on Nov 11, 2015
There are carbon contact on the back side of the rubber buttons, and after a while, these do not make a good connection. It can be cleaned, but that doesn't mean it will restore the functions. Best to buy a new remote.
Universal MX-900... | Answered on Apr 14, 2015
Check the remote control for its infra-red emission.Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV.If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/If the remote control is found OK; check and replace the infra-red sensor inside the TV.Contact any service technician.
Universal MX-900... | Answered on Feb 27, 2015
Have you tried pulling the batteries for a while? That alone may fix it. Sometimes, not many, there is a reset procedure for not only for the unit, but the remote also. If that doesn't work, you will have to replace it.
Next time you ask a question, please give us the type of unit, the make and model number. Without that, we would have to guess what type of product you have.
Universal MX-900... | Answered on Nov 23, 2014
Try removing the batteries, then short out the terminals in the remote. This should discharge any residual power in the components in the remote. Re insert the batteries and it should then work ok
Universal MX-900... | Answered on Aug 06, 2014
You should set up the remote control with the set-up codes to your device brand.
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
If remote control is found OK, and have infrared emission, set it up with your device by using the set-up codes.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
Universal MX-900... | Answered on Jul 20, 2014
One of two options here honey... the battery in the remote is flat and needs replacing or... the remote receiving device in the unit was blown, or now has no power to operate. Change the battery... replace the remote... if the problem remains then the problem lies in the controlled device itself. DO NOT attempt this repair yourself.
The obvious question here is: are the batteries installed the correct way? Here is a web page to download the operator manual:
http://www.universalremote.com/pdf/MX-900OwnerManual.pdf
Also; are your batteries good? are they making good contact? Has the remote been damaged by leaking batteries? Inspect and test.
Do you have the original remote controls for the devices you are trying to control? If so... do they work? Remember... they will need batteries too!
Are there manual switches on the device you want to control? Do they work? Can you turn it on and off?
We are moving through a process to identify which items work, which are good and which are faulty.
Check it ye set it up with an other code to your device. Some universal remote control will behave so. If it has set with an other code, might help you. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
Universal MX-900... | Answered on May 11, 2014
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Universal MX-900... | Answered on Mar 30, 2014
You should synchronise the set with its set-up code after a power failure. If you wish to get more details; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Universal MX-900... | Answered on Mar 28, 2014
Universal MX-900 Remote Control Logo
93 questions posted
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Universal Televison & Video
Most Popular Question
mx 900 universal remote got new
  • Televison & Video
