20 Most Recent
Pinnacle Avid Liquid Version 7 for PC Questions & Answers
After i import my hd video, it is cropped and i
I suggest getting Aimersoft video converter. I use Aimersoft video
converter pro and its very good. You don't have to get pro they have
different versions and trials so you don't have to buy. I would suggest
getting that, because you can remove the black bars from movies. With Aimersoft video converter it supports hd videos and it can remove the black bars. If i helped please leave me a rating.
I need a User's Manual for Avid Liquid 7
Hi tenoniacun35,
Below is a link which is a pdf file for the installation manual for Liquid 7. Let me know if this is what you need.
http://cdn.pinnaclesys.com/SupportFiles/attach/Liquid_InstallG_7_0_EN.pdf
Actually, I just reread your post again and you said you want a User's Manual. Try the site out below. There is an online manual available for viewing for free it looks like. There is also a free trial if you want to try it out. I've never tried it out myself so I can't give you my opinion on it.
http://my.safaribooksonline.com/0321369475
Let me know if this helps,
Justin Rocque
Dragon PC Training & Repair
“Quality Service At Rates Anyone Can Afford”
http://www.dragonpctraining.com
I am a Pinnacle Studio user
Avid is a complete different animal. The logic is backwards from Pinnacle or premiere. If you're used to those, Avid will seem like a forgeign language. Also, projects aren't compatible with Avid.
I have Pinnacle studio 12 and when I want to add a movie I get the comment that I have to install MPEG-4 Encoding/Decoding. Where can I find that file and how do I do it?
To install MPEG-4 Encoding/Decoding, you can try the following steps:
- Go to the Pinnacle Studio 12 installation folder on your computer.
- Look for a folder named "Redist" or "Redistributables".
- Inside the "Redist" folder, look for a file called "MPEG-4_Codec.exe" or similar.
- Double-click on the "MPEG-4_Codec.exe" file to run the installation process.
- Follow the instructions provided by the installer to complete the installation.
If you cannot find the "MPEG-4_Codec.exe" file in the Pinnacle Studio 12 installation folder, you may need to download it from the internet. You can search for "MPEG-4 Codec download" in your preferred search engine and look for a trusted website to download it from. Once downloaded, double-click on the file to run the installation process, and follow the instructions provided by the installer to complete the installation.
Once the MPEG-4 Codec is installed, you should be able to add movies to Pinnacle Studio 12 without any issues.
3/9/2023 6:07:57 AM •
Pinnacle...
Answered
on Mar 09, 2023
Tienes los drivers para el pinnacle
Pinnacle es una marca de software de edici?n de video y audio. Si tienes el hardware de un producto Pinnacle, como el PCTV 801, pero no tienes el disco de instalaci?n, puedes descargar los drivers y el software necesarios desde el sitio web de Pinnacle.
Para descargar los drivers para el PCTV 801, sigue estos pasos:
- Visita la p?gina de descargas de Pinnacle: https://www.pinnaclesys.com/en/support/downloads/
- Selecciona tu producto: En la p?gina de descargas, selecciona el producto PCTV 801 de la lista de opciones.
- Descarga los drivers: Haz clic en el enlace "Drivers" para descargar los drivers necesarios para el PCTV 801. Aseg?rate de descargar la versi?n correcta del driver para tu sistema operativo.
- Instala los drivers: Una vez descargados, sigue las instrucciones de instalaci?n para instalar los drivers en tu computadora.
Para recuperar tu serial, deber?s consultar el manual del producto o contactar a Pinnacle para obtener m?s informaci?n. Puedes encontrar informaci?n de contacto para Pinnacle en su sitio web.
12/25/2022 8:49:26 AM •
Pinnacle...
Answered
on Dec 25, 2022
After ok for years, I now get burning error with my Pinnacle DVD recorder. To both DVD and hard drive. In particular I want to use UscreenCapture.
no PC told or OS
no age of PC (windows 10 is it?) or MAC OR ?
old PC have bad HDD and no bad HDD on earth can send data good to any DVD recorder, I presume DVD-R media.
what does uscreencapture have to do with any of this.?
sure you made your own video, of any kind and type of VAST.
Or any video camera made ever.
then that video file is on your HDD , NOW.
i plays ok. (test 1)
then I run HDD smart test to be sure HDD is good first.
takes all of 5min work, to do . that or less if loaded, now.
then burns work if the dvd-r is good and the DVD drive is not bad or just optically full of lint and fails.
100% free and safe.
https://www.passmark.com/products/diskcheckup/
load that, run that see NO ERROR or you will fail if does.
smart tests are first if data ever ever fails. we do that.
I use Imgburn (free ) to burn mine, done for over a decade never 1 bad disk made.
4/7/2022 6:30:42 PM •
Pinnacle...
Answered
on Apr 07, 2022
Dvd says wrong disc type
Are you trying to burn DVD's?, if that is the case you will need DVD-R or DVD+R. If you have already tried DVD+R, your burner may prefer DVD-R. If you are using a desktop computer, the front of the burner drawer should have a few logos on it, see if you can read what discs the drive has listed, or refer to your owner's manual for that same information.
12/2/2021 7:16:44 PM •
Pinnacle...
Answered
on Dec 02, 2021
