20 Most Recent
Eureka 5892AVZ Bagless Upright Cyclonic Vacuum Questions & Answers
Vacume cleaner
Check the hose and see if it has a clog, also the hose at the bottom. The filters may be clogged, make sure they are clean and that air flows thru them, if not then replace them.
Eureka vaccum won't turn on
There is a thermal reset in the motor that will shut the motor off if it gets too hot from a clog or clogged filters. It will come back on when it cools down. If it does this try to find a clog somewhere and also replace or clean your filters
Eureka 5892BVZ ON/OFF switch burnt
COUNT ME IN ON A CLASS ACTION IF ANYONE KNOWS A GOOD LAWYER.
Here's my story, posted on other solutions here, especially on the Model 5893; many people with burned wiring and switches. Major fire hazard imo! Okay, here's the skinny on my upright Eureka POS vacuum:
Had a problem with my upright Eureka Model 5893
bagless kinda starting and stopping. Eventually, the handle would get hot, and finally it just
quit. When handle was disassembled, the wires were melted and it was
toast. Ordered a switch after talking
to several repair men. Talked to Eureka, too, and they were absolutely
no help. Cheap wiring and switch made in China. Good luck trying to
find a switch. vacuum-depot.com has switches, so you might try there,
but make sure you get the 3-prong switch (same switch used on Eureka's
Genesis). It is Part #27871.
My Eureka 5892 BVZ-1 vaccum has very little
There are probably three filters, one on the back of the dust collection bin, one under the dust collection bin, and one where the air exits the vacuum, check all three.
Gary
Multiple broken belts in months
Either the belt is not tracking straight, the brush roll is bad(check the ends to make sure they turn easily), or the base has warped and the brush roll is not sitting in the proper spot.
How do I locate and find each of the filters?
The foam & filter assembly is behind the clear door with the latch you pull up on, located above the dirt cup. The hepa filter is on the right side of vacuum as you are facing it from front.
Belt
Turn vac over, take out 4 to 5 screws and the top cover will come off. The belt is a cogged belt #72393 and goes between the brush roll motor and the brush roll.
Handle gets very hot on my 5892BVZ vac
i have a 1998 chrysler sebring convertible stop starting by the ignition switch,we changed starter,ignition switch been changed,changed starter relay,trace the wire haven't found a broke are burned place in it,checked igniton fuse its good,didn't see a linkable fuse
Problems with Eureka 5892AVZ Bagless Upright
You may be using the wand/hose without an attachment on it. The attachments on my dyson always allow some air to flow to by, it may be the same on the Eureka. If air flow is completely stopped the cyclone will shut down and then the hair/dust/whatever will flow to the filter. So don't let the air flow be completely shut off during use.
The vacumm over heat?
The filters are clogged and need washing or completely cleaned. Also check all hoses and dust channels to ensure the model is completely cleared out.
Brush spins & then trips & quits
Sounds like a clog to me. Check that the roller brush cap fittings (caps at either end of the brush roll) don't have thread in them as well as checking that the dust channel from the sole plate is completely clear.
Motor is noisy
Hi
Generally modern upright vacs don't have screws that you can undo to get into the motor and most Electrolux/Eureka models have sealed units. I suggest looking at the sole plate where the roller brush is, check for anything clogging the main dust channel and then remove the hoses. Also take out the filters and give them a good clean, washing them are good but you must let them dry (or put in a low temp tumble dryer in a pillowcase with a towel) out.
You'd have to check out Eureka's customer services for an imploded service manual. Check on their website if nothing else works.
Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
