20 Most Recent Uniden Oceanus VHF DSC Radio White Questions & Answers
Hi, I hooked up a furuno gps-320b to my oceanus
You must have hooked the speaker output from the VHF to the nmea output of the GP320 instead of the NMEA!
9/30/2010 10:20:32 PM • Uniden Oceanus... • Answered on Sep 30, 2010
I'm after the wiring diagram to connect a Garmin
You wanted to charge me to provide a solution but now that I've found that solution, will you pay me to give it to you?
2/7/2010 8:51:56 AM • Uniden Oceanus... • Answered on Feb 07, 2010
I had a uniden oceanus installed and when I click
Try moving your antennas further apart. If they are already a couple feet apart, mount the Uniden in another location away from the stereo if possible. You might check with a radio shop about a filter. Your Uniden operates in the 150MHz range and the stereo receives in the 88-107MHz range. Good Luck.
4/19/2009 8:37:37 AM • Uniden Oceanus... • Answered on Apr 19, 2009
3answers
Need free codes for a base police scanner
hello there
please try these links they have worked for me
  1. Scanner Frequencies & Codes Free Trunked Fleet ID's for your area (Works with Scancat) Military Base Operations Frequencies ... Get a scanner frequency list by email for your county, ...www.bearcat1.com/free.htm - Cached
  2. Portland Police Scanner | Portland, Oregon Crime & Emergency Dispatcher ... ... use of a Trunk Tracking Scanner and entering the Talkgroup codes listed in the next section. ... your Business Listing for free. Obits / Death Notices ...oregonlive.com/policescanner/...?/policescanner/police_codes.frame - 64k - Cached
  3. Scanner Feeds ... Feeds Police Codes Police 11 Codes General Codes General Acronyms ... They are free. ... Big Bear, California Police Scanner (web-based) Los Angeles Police ...members.shaw.ca/crazykid755/scanner - Cached
2/7/2024 2:07:07 PM • Uniden Radio... • Answered on Feb 07, 2024
Owners manual Uniden Bearcat BC590XLT
The Owner Manual is here Noel
Bearcat BC-890XLT Scanner owner's Manual
repeater-builder.com https://www.repeater-builder.com > uniden > pdf PDF Please read this Operating Guide thoroughly before operating the scanner. Optional Accessories. The following optional accessories for your BC 890XLT are ... 40 pages ..
6/24/2023 5:09:47 PM • Uniden Radio... • Answered on Jun 24, 2023
Uniden Bearcat BC 220XLT Radio Scanner repair/service manual
Some help here, but what you want to be likely not possible. https://www.google.com/search?q=Uniden+Bearcat+BC+220XLT+service+manual ..
5/23/2023 2:41:51 AM • Uniden Radio... • Answered on May 23, 2023
I need a battery for UBC3000 please?
All questions need full 'make model (what it is)' or we guess. I see a number of UBC3000.
Uniden - UBC3000XLT Battery
Complete Battery Source https://www.completebatterysource.com > uniden-ubc... The Uniden - UBC3000XLT Nickel Metal Hydride (NIMH) battery is the perfect replacement battery at a great price! The Uniden - UBC3000XLT battery is ... Capacity: 1100 Length inches: 2.7 US$43.55
3/10/2023 11:22:58 PM • Uniden Radio... • Answered on Mar 10, 2023
D104-M6B WIRING FOR A UNIDEN 880 RADIO DIGRAM
Here is the wiring diagram for connecting a D104-M6B microphone to a Uniden 880 radio:
  • Shield: Connect to pin 1 of the microphone jack on the radio
  • White: Connect to pin 2 of the microphone jack on the radio
  • Red: Connect to pin 3 of the microphone jack on the radio
  • Black: Connect to pin 4 of the microphone jack on the radio
It's important to note that not all Uniden 880 radios are wired the same way. If you're unsure about the wiring on your specific radio, it's best to consult the manual or contact Uniden customer support for assistance.
2/26/2023 4:12:25 AM • Uniden Radio... • Answered on Feb 26, 2023
Uniden UBC370XLT Scanner. Hello, I am looking for a schematic diagram for a UBC370XLT. Does anyone have a copy or know where I might be able to get one please?
Question edited for clarity and add maker + (what it is). Question moved from Misc. You will have to contact Uniden direct. This search query should find it. The CLT model seems better known https://www.google.com/search?q=UBC370XLT+schematic More here including software https://www.google.com/search?q=%22UBC370XLT%22 ..
1/5/2023 2:36:14 AM • Uniden Radio... • Answered on Jan 05, 2023
Uniden 210 XLT. What modification to pick cell phone frequencies
Question edited into english. No modifications. The range is restricted and the calls are encrypted.
12/1/2022 4:28:40 AM • Uniden Radio... • Answered on Dec 01, 2022
How to wire a Superstar 507-5 microphone to a Uniden Washington base unit please?
It should just connect with the plug eBay states. This is a brand new Workman replacement omni-directional CB radio microphone. Features a 5-pin connector and a flexible coiled cord. Wiring:
  • Pin 1 - Audio
  • Pin 2 - Ground
  • Pin 3 - RX
  • Pin 4 - Common
  • Pin 5 - TX
  • Compatible Radios:
  • Cobra 90LTD
  • Cobra 140GTL
  • Cobra 142GTL
  • Cobra 148GTL
  • Cobra 148-F-GTL
  • Cobra 2000GTL
  • Cobra 2010
  • Uniden Washington
  • Uniden Grant XL
  • Uniden Madison
  • https://www.google.com/search?q=connect+Superstar+507-5+microphone+to+a+Uniden+Washington ..
    11/27/2022 9:08:36 PM • Uniden Radio... • Answered on Nov 27, 2022
    I have an Old Uniden BC760XLT scanner been sitting for months..now it Appears by the display To be Scanning,No Audio I've tried the internal/external speaker/recorder jack ..No Audio..any ideas?
    Probably has some leaky capacitors that stop it from working and just shows a display without tuning at all.
    7/6/2022 5:49:23 AM • Uniden Radio... • Answered on Jul 06, 2022
    I just received a Uniden Bearcat handheld scanner model BCD325P2.
    all it can do is in the manual. 2015 made new. all those safety channels frequencies are regulator by FCC.gov and are published here they are, first google hit ,amazing. https://www.radioreference.com/db/browse/stid/12 keep in mind some 800MHz transmitters (gov) are encrypted trunking mode radios, (like police is) in my town text, the HAM band 2meters has full time weather brocast (I have HT and HF here) our RAD does 25mHZ to 900mHz bands all stated in the manual below. page 129 covers the public service bands starting at 758.0125 MH vhf and uhv is line if site comms so that is why there are so many stations. (broad casting) best is try the closet one first. a better antenna , is what to use. what kinds of safety data do you need, not told fire, police , amber alerts, weather, road reports, and lots more what you want not told. but you can find it if you google that, in clear simple text. for sure. by county is best. as it is line of site. police bands are trunked and have are networked sites to overcome line of site issues,. (magic) and is encrypted.(and ******* to hack btw) broadcast is site by site and 20 miles max (aprox) but station power in watts is prime there, and no 2 stations are the same, (rare) set the radio to scan them all , see what it finds.? be patient. or look up what you want googled. https://www.manualslib.com/manual/952528/Uniden-Bcd325p2.html?page=129#manual good luck and happy DX'ing.
    7/2/2022 3:06:23 PM • Uniden Radio... • Answered on Jul 02, 2022
    How to setup a uniden BC75XLT BEARCAT?
    https://www.roadtrucker.com/images/manuals/uniden-bc75xlt-user-manual.pdf
    6/12/2022 11:17:03 PM • Uniden Radio... • Answered on Jun 12, 2022
    Uniden scanner won't scan
    If your Uniden scanner won't scan, there are a few things you can do to try to fix the problem. The first thing you should do is check to make sure that the scanner is properly plugged into an outlet and your computer. If it is plugged in and still not scanning, try restarting your computer. If that doesn't work, you may need to update the scanner's software. You can download the latest software updates from Uniden's website.
    3/17/2022 4:52:11 AM • Uniden Radio... • Answered on Mar 17, 2022
    Uniden Bearcat 800 XLT Radio Scanner. What IC chip controls the display?
    Question edited for clarity and capitalization.Question moved from computers.Not controlled by an IC. There are some ideas in the link, but check the back of the display for a capacitor. If there is one replace it.https://www.google.com/search?q=uniden+800+xlt%2C+display+dim..
    3/11/2022 12:39:51 AM • Uniden Radio... • Answered on Mar 11, 2022
    Uniden bearcat scanner 800 xlt comes on but screen will not display
    Download a schematic from modsdk.com or radio reference.com.Then change the two regulators in the back left corner.Should be a 78mo5 and a 78mo9.THE 7805 is the one usually goes out.
    3/11/2022 12:32:25 AM • Uniden Radio... • Answered on Mar 11, 2022
    Uniden Oceanus VHF DSC Radio White Logo
    6 questions posted
    Top Uniden Radio Communications Experts
    John
    John
    eradiostore
    eradiostore
    Grand Canyon Tech
    Grand Canyon Tech
    Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
    View Most Popular
    • Uniden Radio Communications
    Most Popular Question
    hooked up furuno gps 320b oceanus
    • Radio Communications
