20 Most Recent Uniden BC60XLT Handheld Scanner Questions & Answers
4answers
Owners manuel BC60XLT-1 30 channel 10 band radio scanner
one of the following should be the correct one, both are for the same model, but i believe there may have been submodels
http://www.uniden.com/pdf/bc60XLTom.pdf
http://www.racescanners.com/~draley/ScannerManuals/BC60XLT-1om.pdf
11/10/2016 7:46:51 AM • Uniden BC60XLT... • Answered on Nov 10, 2016
2answers
Uniden bearcat bc60xlt-1 channels wont unlock
Channels have to be programmed with a frequency before the scanner will allow them to be unlocked. The L/O indicator should automatically turn off once a frequency is in memory.
4/5/2016 2:59:25 AM • Uniden BC60XLT... • Answered on Apr 05, 2016
Programming a scanner
To program a BC 70XLT turn the scanner on and hit the man key.
enter the channel you want to program (ie 1) hit the man key again then enter the frequency you want to scan (IE 450.625) then hit the E key to enter the freq into the location if you want to sequence to the next channel then hit the man key again enter the freq and hit the E key.you can go through all 20 channels this way.
12/23/2015 6:10:14 PM • Uniden BC60XLT... • Answered on Dec 23, 2015
How to program Uniden BCD396XT digital scanner?
Easier to Read BC346XT Scanner Manual
7/12/2014 5:36:00 AM • Uniden BC60XLT... • Answered on Jul 12, 2014
2answers
A letter p is poping up in front of one of my channels as its scanning why
The letter P is for Priority. The channel with the letter P is set for Priority. When the scanner is operating, anytime a signal goes to that channel it will automatically switch to it and you will hear the transmission. If you have the user manual you can see how to set it. You can usually find a copy of the manual on line, or google for instructions.
6/14/2014 8:13:49 PM • Uniden BC60XLT... • Answered on Jun 14, 2014
I have a bc60xlt andno matter how i turn the squelch i get the same hiss what happened
The Bearcat Scanner is neat hand held scanner, Is the scanner programed? Depress the WX for weather and see if the weather channel is available. The squelch knob should be turned clockwise and the noise level should decrease (actually you are decreasing the allowable signals to be received). If you get no response from a know frequency, then the squelch pot may need cleaning or replacement may be in order.....Cost for repair at service shop may not be feasible.
5/26/2014 7:59:53 AM • Uniden BC60XLT... • Answered on May 26, 2014
0answers
How do I use it
12/26/2013 12:11:52 AM • Uniden BC60XLT... • Answered on Dec 26, 2013
Uniden BC60XLT hand held scanner Help on how to program
A downloadable copy of the manual is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
7/3/2013 5:57:10 AM • Uniden BC60XLT... • Answered on Jul 03, 2013
0answers
Cannot receive weather channel information
Antenna connected? Station off air due to bad weather? Is the 'squelch' set to you hear static, then turn it back just to where it stops hissing? Try that and let me know.
3/8/2013 7:16:40 PM • Uniden BC60XLT... • Answered on Mar 08, 2013
8answers
Uniden Bearcat BC60XLT 10 Channel 10 Band Radio Scanner with L/O on every channel #
Turn off power, hold down the 2, 9 & L/O buttons while turning the power back on.
2/21/2013 7:00:57 PM • Uniden BC60XLT... • Answered on Feb 21, 2013
I HAVE A BC346 XT I NEED A PROGRAMMING MANUAL
You may access the manual here.
12/3/2012 5:54:07 PM • Uniden BC60XLT... • Answered on Dec 03, 2012
Uniden BC60XLT Handheld Scanner Logo
150 questions posted
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Uniden Radio Communications
Most Popular Question
programming scanner
  • Radio Communications
