20 Most Recent
Pride Mobility Products Jazzy 1113 ATS Questions & Answers
Can the batteries or my charger be bad on my Pride Jazzy 1113 ATS?
The MK batteries are far superior to Interstate batteries overall.
You can load test the batteries to see if they are working properly with a load tester. Your can test the charger output to the batteries with a digital voltmeter connected to the batteries with the charger plugged in. These 2 tests take less than 10 minutes and can be done at a local auto or scooter shop for nominal expense.
Make sure the charger and battery connections are tight and free of corrosion. On the VSI of the Jazzy 1113 there is a notorious problem with 8 pin connector and 3 pin molex at the back. You can clean these connectors but a complete electrical rebuild of the pins and receptacles is sometimes required if significant corrosion has set in. Try spraying electrical cleaner and use green Scotchbrite to clean the metal tabs on the 8 pin connector. Make sure the 3 pin molex sits in the receptacle and is making good contact.
Hope this helps.
Jazzy 1113
Unit has a full
Go ahead and try this web site.It will give you the flash codes and narrow down your search to finding the problem.http://www.pgdt.com/scenter/diagnostics/diagvsi.html
My jazzy 1113 won,t come out of slow mode
Hi.Sounds like faulty motors to me. Check brushes and brake units. How much work has the machine done.
These motors develope a build up of carbon and copper dust from the brushes and commutator. This dust can cause a partial short from the armature to the outer casing of the motors. What happens then is the signal from one motor leaks through to the other motor causing the controller to think its developed a fault. A good serviceman can tell you if this is the case. Good luck. Neil.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
