Wire positioning doesn’t matter to soap dispenser. If water is leaking from the door then the dispenser is not pressed in properly against its seal. As far as the door not opening if wires are connected perhaps the problem is in the control module. Voltage meter on wiring to dispenser should indicate this while machine is running at start of quick wash cycle. (First 5 minutes of cycle on heating)
This is a partial solution. After reading lots of other similar descriptions (none of which were automatically identified by FixYa, btw), we realized it was probably water in the 'catch basin' or whatever that pan (white plastic) below the sump pump is. Sure enough, there was about 1/2" of water in the pan. We hoped that by overriding the float switch and watching it run through a cycle, we would be able to see where the leak came from. Unfortunately, running a rinse & hold (10 min) didn't do it, so we are about to run it on a quick wash (56 min). To do this, we have left everything connected (power & water), and removed the toe kick cover, to give us access to the works below the main compartment. A long chopstick works well to get at the red float switch actuator; we used two of them to dip a washcloth in the water to soak, and then remove the washcloth and wring it over a bowl. Slow, and tedious. But the alternative was to do the 3 hr teardown just to get the pan dried before we could run it through a complete cycle. We're still hoping this will let us see the leak.
Unless the motor and pump are an assembly permanently fastened as a unit, you probably need only replace the pump.
Motors can be made really poor but will outlive the pump.
Since Bosch is a German brand, it may not be found on the Sears parts pages but it is worth a try.
Just go to Sears.com and click onward for parts.
Quorahttps://www.quora.com > What-does-CL-mean-on-a-dish...
This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ...
9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
JustAnswerhttps://www.justanswer.com > Appliance Repair
Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone.
1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your
..https://www.youtube.com/watch?v=Xr4DBwACUW4
Dishwashers come in standard sizes. Your old one is 60 CM wide and made for built in.
https://www.bosch-home.ca/en/supportdetail/product/SGU4025AU/31
DISHWASHER 60 CM BUILT-IN/BUILT-UNDERSGU4025AU/31
As long as the new one is also for built in, the dishwasher will fit. Measure the height of the space you have. There may be a little height adjustment on the feet.
AI Bot Answer Deleted.
In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
