20 Most Recent
Bosch 24 in. SHU53 Built-in Dishwasher Questions & Answers
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Door on detergent container hard to close
You can try cleaning the cover assembly with a small brush (tooth brush works well), but the mechanism may be worn or broken and need replacement. This should be replaced as an assembly, not just the cover door.
Error 23 in bosch dishwasher
E23
Winding resistance of drain pump fault.
The controlled has detected a break or short in the drain pump wiring. Many of these dishwashers use this pump which is a cheap compatible one.
Dado
Bracket to keep unit from falling over
Built in dishwashers usually have screw holes in the sides to screw directly to the adjacent cabinet. Have a look for plastic plugs down the inside of the cabinet opening and take them out to see if the holes go all the way through to the outside.
Is there a Reset button for Bosch shu53 dishwasher?
Press and hold Scrub Wash and Delicate/Econo buttons at the same time for three seconds. This will advance the unit to "CL" (clean), meaning the washing cycle is finished, and will drain the water. Do this if your unit gets stuck on 1 minute left, which is common with this model. (I am told that the control panel melts over time, and that the unit is not designed to last more than 10 years.)
How do i run a test / diagnostic mode for the bosch sge63e05uc (evolution series) dishwasher?
Are the instructions on how to run the diagnostic test listed in the manual? FYI, I couldn't run the test on my Bosch DW because it was just too broken. Over the years the dishwasher essentially fried its own circuit board with excessive heat, which I learned is a problem common to Bosch DW's. Bosch told me the lifespan of my model was 10 years; mine was 11 years old (but was repaired once or twice). I replaced it with a Miele; no problems yet after 4 1/2 months.
Need reset sequence
o reset the control module AP2802870, you will put the dishwasher into the cancel/drain mode and let it complete the cycle. When you installed the new control remove the jumper from the original front lower right hand # 1 board male port. Starting from the extreme lower rt.corner, there is a 6-terminal connector with a jumper wire looping # 5 and # 6 terminals. (counting from the right to the left). Use this on your new board. Then reset the controls.
