20 Most Recent
Yamaha 1,000 Watt Portable Generator #EF1000ISC Questions & Answers
Can the ecu memory be flashed on a Yamaha EF2800i
It sounds like its running on the gas in the carburetor and not the gas filling back up to run more, I bet you have a gas supply problem to the carburetor! Try Babbitts Yamaha Partshouse online...
Yamaha ef1000 will start then push choke in and generator stops
clean tank fuel lines air filter and completely clean all carb parts and jets just did mine runs mint now did the same thing i also put in a new spark plug changed the oil a good once over goes a long way just take your time use a good carb cleaner like crc or gumout and check the jets they have small holes on the sides that can clog up hope this helps
How long will it take
That will depend on the charger that you are using. If you use a 10 amp. charger it should only take about two hours for partial charge and up to six for complete. Thank you
Yamaha ef1000is was rained on, starts and runs
Sounds like the rectifier got fried. Moisture in these units is a dangerous thing. Even if you feel the unit sat long enough to dry ouit, it sometines will hold moisture in the electrical componants.
Generator won't start
i have the same problem. i took out the air filter and sprayed tb into it and it ran and died. this is the only way to get it to fire up.
i took off the carb, dissasembled it and blasted it out with tb cleaner, took out the jets too, put it all back and it still does the same thing. it is getting fuel but it won't run.
need a profesional answer on this one please.
thanks, tom.
