20 Most Recent Yamaha 4500 Watt Electric Start Generator - EF5200DE Questions & Answers
2answers
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
1/6/2020 8:16:32 AM • Yamaha 4500 Watt... • Answered on Jan 06, 2020
Generator runs but want generate no power
How to test your Electricity Generator AVR Brushes and Alternator on... Need more advice? Contact us, we are always happy to help! http://www.generatorguru.com/ask-the-guru/ Regards The Generator Guru Team
5/10/2018 10:08:01 AM • Yamaha 4500 Watt... • Answered on May 10, 2018
Oil sae
I can not see why you want to use that oil. That would be a good oil to use if you have a lot of hours on that engine. Otherwise it is a little high on upper viscosity number unless it is running really hot and I doubt that is the case.
7/22/2013 1:04:40 AM • Yamaha 4500 Watt... • Answered on Jul 22, 2013
I have an EF4600DE.
this is a brushless generator, that means it has a condensor, this is a "normal" fail, see it happen a lo on brushless. Upgrade to a metal can condensor (gets less heat and is a better construction and the problem should be less frequent... If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_573a00ba7e399076
3/1/2011 4:35:02 AM • Yamaha 4500 Watt... • Answered on Mar 01, 2011
What servicing can I do for my generator which has
change the spark plug clean the fuel tank replace filters and oil change fuel line if cracking or stiff.
remove carb bowl clean out with carb clean remove any sch-lack from old gas run and test power.
hope this helps
8/31/2010 11:45:57 AM • Yamaha 4500 Watt... • Answered on Aug 31, 2010
3000 watt yamaha generator is really hard to start
sounds like the carberator needs cleaning and the linkage that makes it open up under load. it works off the flywheel. a lot of generator problems are gas related. water, trash and varnish build up in the carb.
8/30/2010 2:46:09 AM • Yamaha 4500 Watt... • Answered on Aug 30, 2010
Had to tickle the throttle on my yamaha 3500 watt
You should have automatic or manual choke control. Try to find it and open it during start. After that you can close it if stable work is achieved.
6/13/2010 7:26:55 PM • Yamaha 4500 Watt... • Answered on Jun 13, 2010
With my generator running i have ac power but my
Make sure your generator is rated high enough to run you a/c. Also is you a/c 120v or 240v? Do you have it plugged into the right voltage?
5/12/2010 2:13:09 AM • Yamaha 4500 Watt... • Answered on May 12, 2010
My generator might be broken
Check the breakers.take it back if its brand new.
5/10/2010 5:11:00 PM • Yamaha 4500 Watt... • Answered on May 10, 2010
Check if a circuit breaker is tripped and reset it.
4/1/2010 2:48:30 AM • Yamaha 4500 Watt... • Answered on Apr 01, 2010
2answers
Onan Marquis Indiana 5000 generator
You MAY have blown the rotating diodes on the rotor.
This would require servicing.
1/2/2010 1:17:35 AM • Yamaha 4500 Watt... • Answered on Jan 02, 2010
Rv Generator does not put out any ac power, but cranks great
could be a bad transfer switch.
7/16/2009 3:46:42 AM • Yamaha 4500 Watt... • Answered on Jul 16, 2009
I have a Yamaha Ef2600 fw generator that starts and produces voltage and current but also gives out a 'clunking' noise on a 2 - 4 second cycle. What is wrong with it?
Based on the search results there are a explanations, for the clunking noise in your Yamaha EF2600FW generator; 1. Load handling; One potential reason could be that the generator is facing difficulties in managing the load, which could be due to fuel or air supply. This can result in the generator producing a clunking noise. 2. Fuel shortage; Another possible cause might be a lack of fuel supply to the generator leading to a knocking sound. It is advisable to address this fuel issue before operating the generator to prevent any damage. 3. Storage conditions; The clunking noise could also arise from storage conditions. Over time certain components like piston slap or dry rod bearings may develop problems resulting in sounds when the generator is running. To diagnose and resolve the problem with your generator it is recommended that you take the steps; Check and ensure a fuel supply. If needed, clean or replace the carburetor. Inspect the generator thoroughly for any signs of damage or wear in areas like piston and rod bearings. These actions should help. Rectify any issues causing the clunking noise, in your Yamaha EF2600FW generator. If the problem continues you might need to reach out to a technician or get in touch, with Yamaha customer support for help. Always prioritize safety when dealing with generators or any other equipment. If you feel uncertain or uncomfortable about troubleshooting or making repairs yourself it's best to seek assistance, from a professional.
8/25/2023 9:54:21 PM • Yamaha... • Answered on Aug 25, 2023
No power generation
The reasons of no power generation: 1. The voltmeter of the control panel is damaged or the wiring is in poor contact. This situation is generally after the diesel generator starts normally, and the voltage on the meter sometimes does not move. It is necessary to use a multimeter to measure the U, V, W, N phases of the motor, and the phases between U, V, and W. The voltage is about 400v, and the voltage between single-phase U, V, W and N is about 230v. 2. The air switch on the electric ball in the diesel generator is damaged: the phenomenon that occurs is that the diesel generator is normal when it is started, and it trips when the load is turned on. 3. Brushed motor equipped with diesel generator: The disadvantage of brushed motor is that demagnetization occurs occasionally, so it is necessary to keep 1-2 pairs of carbon brushes to prevent this situation. 4. The starting elements are not reached: the starting elements of diesel generators refer to the speed of 1500 rpm, frequency of 50HZ, and voltage of 400v. Many users feel that the noise of diesel generators will be very large when this data value is reached, so they reduce the speed by themselves. , the consequence is that the voltage is not enough, the frequency is not enough, and the power is not generated. After a long time, the power of the diesel generator will be insufficient. 5. Damage to the voltage regulating plate: The function of the voltage regulating plate is to adjust the excitation current correspondingly according to the change of the generator load, so as to maintain the terminal voltage as a given value, which can obviously smell the smell of burning. The above are the common reasons for the failure of diesel generators to generate electricity summarized by our editor. We hereby suggest that if your diesel generator has not expired, please contact the diesel generator manufacturer to provide guidance on operation, and try not to repair it yourself. More solutions, you can visit https://www.dbdieselgenerator.com
7/23/2022 8:14:35 AM • Yamaha... • Answered on Jul 23, 2022
2answers
How to fix surging
Very old thread but here goes., My 2400is was surging under light load but I was able to fix that with a new idle jet and thorugh carb cleaning. Now, it doesn't respond to various loads and will not rev up, ie., stays at idle and quits. Manually opening the throttle works fine. I took out the solenoid and cleaned the spindle but didn't help. When it was out, turning it had some resistance (felt like a rehostat, a bit rough and definitely not spinning freely) . Dunno how it should feel but, for example, with the engine not running if I move the throttle (controlled by the solenoid) it will "stick" in that position and not return to the idle position by the return spring. Would like to know if that's normal or not! With the engine running, it will return to the idle position and I use a clothespin to keep the revs up even under no load. At least that way it stays running and supplies adequate power. Ideas?
3/16/2022 11:54:42 PM • Yamaha... • Answered on Mar 16, 2022
Yamaha EF6600E generator hard starting and stalls when demanding power
The OHV engine requires periodic valve adjustment.
9/16/2021 9:24:48 AM • Yamaha... • Answered on Sep 16, 2021
Yamaha ef 1400 generator runs but not producing power
Check the brush holder for worn brushes. If they seem ok then the voltage regulator has failed.
5/23/2021 10:50:16 AM • Yamaha... • Answered on May 23, 2021
Yamaha 2000 generator won't produce power, runs fine otherwise
The generator does not operate in accordance with the specified technical conditions, such as too high stator voltage, iron loss increases; if the load current is too large, the copper loss of the stator winding increases; if the frequency is too low, the cooling fan speed becomes slow, affecting the heat dissipation of generator; the power factor is too low, so that the rotor excitation current increases, resulting in the rotor heating. Check whether the indication of monitoring instrument is normal. If it is abnormal, necessary adjustment and treatment must be carried out to operate the generator in accordance with the specified technical conditions. Diesel generator set more supports: www.dieselgeneratortech.com
4/11/2020 3:13:58 AM • Yamaha... • Answered on Apr 11, 2020
Yamaha 4500 Watt Electric Start Generator - EF5200DE Logo
16 questions posted
Top Yamaha Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
MrFixitSTTL
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Electrical Supplies
Most Popular Question
onan marquis indiana 5000 generator
  • Electrical Supplies
