20 Most Recent Proform 760 CrossTrainer Treadmill Questions & Answers
My Pro-Form treadmill purchased from Costco circa 7 yrs ago keep stopping when increasing the speed to about 4-5 mph, parts are no longer available, but dont know how to assess what is wrong. Please h
The issue could be that there is too much load on the motor when going up to the higher speeds. The sensor can detect that there is too much load and shutting down the control circuit. The load can be caused by inadequate lubrication to the driving motor. The motor can be wearing out too. Could also be a circuit issue as well that it cannot sustain higher currents needed by the motor. This is hard to pinpoint exactly.
1/25/2015 4:04:31 AM • Proform 760... • Answered on Jan 25, 2015
2answers
Describe your proform 765 ekg
The problem you have is one of two things. 1 you have a loose walk belt, or 2 you have a spun front drive pully.
You need to remove the front cover to be able to observe the drive belt as it is turning on the drive pully( on the LH side of the front roller) try to stop the walk belt while traveling at speed setting 3. Hang on to the side handles, if the drive belt runs as normal, watch the front roller it will be slipping. If this happens you will need to replace the front roller. If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
9/12/2014 4:50:58 PM • Proform 760... • Answered on Sep 12, 2014
IS HOUSE VOLTAGE ENOUGH TO POWER HEALTHRIDER 500
Yes.
11/20/2013 2:55:36 AM • Proform 760... • Answered on Nov 20, 2013
2answers
My proform 760 wont turn on....
Check if you are getting power to the treadmill by simply plugging in a lamp first to the outlet then check if the on/off reset is engaged.
Then if you have to proceed to under the motor shroud (See owners manual for removing shroud) you will need a multi-meter to trace back to the Motor Control Board to see if you are getting AC Power.
Then if you have power up to this point you'll have to check the wire harness leading to upper console to see if it has proper DC ( 5v or 12v ) voltage leaving and going to the upper console. If you have voltage leaving the board, if not replace the lower board, if you have no voltage reading to the console replace harness, if you do then either the safety key circuit or upper console is defective. Call Iconfitness @ 1-800-999-3657
5/24/2013 9:22:19 AM • Proform 760... • Answered on May 24, 2013
Hallo, I have a problem with my PROFORM 760 AIR, and when it takes 3 or 4 minutes. for themselves, or when X passes also for speed.
tes the speed sensor. RUN the software calibration for troubleshooting and fix it. God bless you755de5d2-2307-4164-9313-a5be55a48396.gifVersion:1.0 StartHTML:0000000168 EndHTML:0000003648 StartFragment:0000000468 EndFragment:0000003631
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
4/11/2013 4:01:33 PM • Proform 760... • Answered on Apr 11, 2013
Type your problem for a solution...where do you
Dear Sir:
Hello I hope everything is o.k
I will try to help you, please to the next web page, is from Proform.
Explore www.iFit.com for details.
Thank you in advance, sincerely. God bless you.
If you need further assistance, please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
11/28/2012 4:10:17 AM • Proform 760... • Answered on Nov 28, 2012
Where are the batteries
normally the batteries goes under the display board.2) see your instruction manual,please download from www. iconservice.com or www.fitness.manualsonline.com God bless you
6/29/2012 10:55:20 AM • Proform 760... • Answered on Jun 29, 2012
Is there a weight limit
not sure if there is a weight limit but did you check the belt tension.
front or rear roller should have an adjustment screw on both sides to tighten the belt. this could be the solution to your problem
8/24/2011 3:02:42 AM • Proform 760... • Answered on Aug 24, 2011
0answers
2answers
I stand on the belt
Observe the belt to detect any fraying. When a belt becomes worn, the frayed area creates more friction and resistance. This increases the heat and power requirements on the motor. The treadmill detects the problem and shuts off the power. If the belt is loose, use the Allen wrench to tighten the tension by adjusting the screws on the back of the treadmill. Turn the screws 1/4 inch clockwise to tighten the belt.
Step 2 Feel the area in the center of the platform underneath the belt. This area should feel slick. If the treadmill platform and belt aren't lubricated, friction causes too much resistance, and the motor shuts down. Check this to lubricate it.
7/12/2011 6:35:25 AM • Proform 760... • Answered on Jul 12, 2011
After walking for about 5 min the overload trips,
It might need to be lubricated, after being vacuumed out. Crack her open and check it out!
3/1/2011 11:08:33 PM • Proform 760... • Answered on Mar 01, 2011
I have an Proform 765
HAVE YOU TRIED TO CONTACT PROFORM DIRECT. SOMETIMES THEY CAN HELP OVER THE PHONE. GOOGLE THEM
9/26/2010 11:03:28 AM • Proform 760... • Answered on Sep 26, 2010
0answers
Proform 760 CrossTrainer Treadmill Logo
Popular Tags
44 questions posted
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
hallo problem proform 760 air when
  • Exercise & Fitness
