20 Most Recent Proform Crosswalk 500 Treadmill Questions & Answers
So after reading the post from EricLaw, I wanted to clarify his solution because it also worked for me. When you open up the console, you will see the membrane (it actually says membrane inside very small) and the connecting wires to the membrane is actually a wide flat plastic with some stripes embedded in the clear plastic which can be easily detached from the membrane (looks like masking tape w/ stripes). These stripes are how the touch pad on the console talk to the membrane. I then took scissors and cut slits between each stripe (cutting only the clear plastic part of the plastic tape) so that I could leave a strip out of the membrane. I played around leaving different strips out until the right strip was left out. If I recall correctly, I left the 5th strip out and the key pad now works entirely EXCEPT the speed 1 and 4 which were the only keys working until I did this. Hope this helps.
Proform... | Answered on Apr 29, 2018
You must LUBE the roller bearing front and back with WD-40 very well. .
2) Examine the drive belt motor, if are very tight, must be deflection 1/8" other wise the ball bearing of motor are very tight.Tight very well the bolt of motor.
3) Run again, if the problem persist, the Rollers are Faulty. Replace.
Treadmill Repair worn belt roller bearings
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Proform... | Answered on Nov 26, 2017
Dear Sir,
if you need further help please contact our local customer care: technicalsupport@technogymusa.com.
They'll be very happy to help you.
Technogym Headquarter
Proform... | Answered on Nov 17, 2017
1)Examine, the board or Running deck, if the holes where the screwdriver are Looses, TIGHT very well, and see if there are doing correct .
Normally this happen when the person training is Jumping, Is NOT normally doing this. Since this machine ARE not Heavy duty like as the machine GYM.
Repair or Replace.
2) As a TIP LUBe the bearing Rollers front and back with WD-40
Blessing.
Proform... | Answered on Nov 03, 2017
Try putting the treadmil in a cooler location. the heat is effecting the mother board.
Proform... | Answered on Jul 26, 2017
just change the Diodes D4015L and SCR´s S4015L whit a caugting buy the new change and ready or is a MC-2100 w / transformer just change the MOSFET IRF250N
Proform... | Answered on Oct 29, 2016
It should be an adjustment of the roller.
Proform... | Answered on Jul 20, 2015
USE THE PATIENCE, CAREFULLY, AND BASICS TOOLS.
Watch this Video:
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
Friction is the #1 cause of this problem. Many cheaper treadmills have amotor with a cardboard core (people wonder why we are so down on cheap treadmills) and if the voltage and amperage through themotor heats it up sufficiently, it begins to smolder. If this is the case, you normally have to replace the belt and the motor and inspectthe deck. If the armature has cooked enough in the motor, you also have to replace the motor. If the belt and deck check out OK, check for a short in the motor. Youcan run the motor with an independent power source like a fullycharged cordless drill battery to see if the symptoms are the same. Click on thefollowing link for our motor test. If the belt and deck check out and the motor is OK, then check yourwiring and electronics for signs of scorching and replace the appropriate part(s).
Sincerely. God bless you.
If you need further assistance, please reach me.
Proform... | Answered on May 28, 2015
Dear Sir:
I will try to help you, use the patience, carefully and basic tools.
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
If you need further assistance, please reach me, sincerely. God bless you.
with this you must fix it.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
motor brushes are bad that is why motor can not start itself
Proform... | Answered on Dec 08, 2014
Either your Motor or Motor Control Board(MCB) is faulty.
Try testing your Motor with a Drill Battery:
1. Disconnect the machine's power lead from the power socket, so that there is no power to the machine.
2. Open the Motor Hood.
3. Disconnect the Motor + and - leads from the Motor Control Board.
4. Connect + and - leads(normally Red and Black) to the Drill Battery.
The Motor should turn the Belt.
With the Motor leads disconnected from the MCB, you can connect the machine to the power, Press Start, and if this trips your Fuse Box you know its definitely the MCB.
Only carry out these tests if you are competent.
Lethal Voltages are present.
samsfitnesssolutions.co.uk
Proform... | Answered on Oct 01, 2014
Your problem may be as simple as a loose walking belt. It could also be that the belt guides on the underside of the deck is too wide. Ir could also be that your rear roller collapsed (there should be noise in this case) or your rear roller screw is broken or not holding tension for some reason. Try adjusting the belt again. Consider that the belt will move to the side of least resistance so if you tighten the left side the belt will move right and vise versa. Good luck. You can contact Techmotionusa.com if you need phone support or service. 5f7cd917-9163-4230-9ba4-58ee24661c26.jpg
Treadmill Repair Fitness Equipment Repair Parts Services Fitness...
Proform... | Answered on Sep 25, 2014
Proform Crosswalk 500 Treadmill Logo
228 questions posted
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Android Man
Android Man
jay kaye
jay kaye
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
mc 2000 es
  • Exercise & Fitness
