20 Most Recent
Nintendo DS Pink Console Questions & Answers
My DS says loading on the top screen! Help
I had this problem for awhile. Go to the R4DS home page (google it) and download the most recent firmware. If you have a R4DS clone, then you will need to find the home page of that device and download the firmware there. If the files are zipped, extract thim with the default Windows zipped files manager or 7-zip. Copy all the files inside to the root of your 2gb card. This should fix the problem.
I cant get my dsi to play games with r4 card,,even had r4 card downloaded with new games
The DSi has several system updates specifically designed to block flashcarts such as the R4. Check the R4 website to see if they have information on what to do if your DSi has blocked the cart. You might be able to do an update to the R4 to fix it. Another option is to get a different cart that has a work-around built in, such as the "SuperCard DSTwo" which has a small chip inside it that other carts don't have and has a file you can download directly onto the memory card that goes into the cart to update it whenever that happens.
What is the wep key?
A WEP key is a password on your router or that is on your router used to protect others from accessing your internet and a password is requires to access it
0000fefe
HAHAHAHAHAhaHHAHAHAfjeaiajfiu!
No idea what you mean.
Nintendo dsi shut off
I'm going to say your Ds is damaged from the water and has finally decided to putter out and fail. Unfortunately I think your only option is to get a new handheld. Sorry man.
