20 Most Recent Malibu ML300RTW - Low Voltage Power Pack -300 Watt - With Timer and Ground Questions & Answers
H ow to replace timer with phot0 cell
Malibu ML300 has 120 volt input and 12 volt AC output They make a photo eye for the timer... wiring is changed a bit... will work on ML300 if timer has A-B-C wiring terminals http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire You can use a 120 -> 12 volt ac transformer that is rated for 300 watts... and connect in-line photoeye on the 120 volt side. http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html http://waterheatertimer.org/Reverse-photo-eye-so-it-turns-on-at-daytime.html Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/19/2015 6:17:00 AM • Malibu ML300RTW... • Answered on Jul 19, 2015
I have a Malibu 300 watt ML300rtw, timer goes until it reaches "on" pin then stops. if i manually turn timer, i hear click and lights go on - they turn off no problem. pins are not broken. what next?
Sounds like the mechanical timer assembly likely has never been lubricated, You may use a lightweight oil, such as WD-40, to lubricate the timer mechanism.
5/10/2015 7:36:36 PM • Malibu ML300RTW... • Answered on May 10, 2015
My ML300RTW timer does not keep the correct time. Can it be repaired?
Probably not. Remove trippers from dial...Plug power pack into cheap wall timer http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:17:53 AM • Malibu ML300RTW... • Answered on Oct 17, 2014
Do you have the clock for M L 300 R T W
Clock motor not sold separately http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 2:53:52 AM • Malibu ML300RTW... • Answered on Oct 17, 2014
What is the difference between the ML200RT and th ML200RTW
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#manual RTW has ground shield. Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 2:46:46 AM • Malibu ML300RTW... • Answered on Oct 17, 2014
How do I reset the 300 watt Malibu lv?
There is no reset button for ML series power packs: Copy following link for troubleshoot resources, replacement trippers, installation tips and manuals http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene h If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/29/2014 11:33:57 PM • Malibu ML300RTW... • Answered on Jul 29, 2014
My malibu timer seems to get stuck before turning itself on. It take 1 hour to trip the timer to come on?
1) Clock motor is worn out, or gears are dirty:http://waterheatertimer.org/Malibu-power-pack-stopped-working.html2) Take apart clock motor and add white grease to gearsSet override to ON, and plug timer into cheap wall timer.Take advantage of 5-year warranty. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3/10/2013 12:05:39 AM • Malibu ML300RTW... • Answered on Mar 10, 2013
Loud huming from my 300v low voltage lighting transformer
Transformers make humming sound.ML300 series transformers make sound.Used styrafoam to separate transformer from contact with building so sound is not carried.These transformers have 10 year limited warranty.Copy following link for general troubleshoot and tips, and warranty information, and trippers.http://waterheatertimer.org/Malibu-power-pack-stopped-working.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/24/2012 6:22:49 AM • Malibu ML300RTW... • Answered on Oct 24, 2012
Malibu timer motor won't turn on, but it turns off ok. I want to replace the timer unit, where can i get one
The timer module is not sold separately.Malibu has 5-year limited warranty against defects in workmanship.If the transformer still works, then plug unit into cheap wall timer.If the timer dial still keeps good timer, then order trippers.Copy following link for manuals, tips, replacement tripper numbers and general troubleshoot:http://waterheatertimer.org/Malibu-power-pack-stopped-working.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/16/2012 2:47:24 AM • Malibu ML300RTW... • Answered on Aug 16, 2012
0answers
I have a ML300RTW: Low
Open following link for troubleshoot steps that give full rundown for setting timer plus replacement trippers, wiring, warranty, and tips for protecting power pack:
ML300RTW instruction manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/professional%20lighting/ml300rtw.ashx
http://www.intermatic.com/products/professional%20lighting/low%20voltage%20landscape%20products/power%20packs.aspx
8/6/2011 11:23:35 PM • Malibu ML300RTW... • Answered on Aug 06, 2011
Can i buy parts to
You can buy trippers for Intermatic ML series, but there are no replacement clock motors or transformers.
I don't know if tripper is the problem or maybe clock motor is getting weak, and will stop working.
If timer is not working, but manual override works, then buy cheap plug-in timer and plug power pack into cheap timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
3/6/2011 11:27:23 PM • Malibu ML300RTW... • Answered on Mar 06, 2011
How to troulbe shoot my 300-Watt Power Pack/Timer.
'Harry' wrote to me yesterday with handy malibu information.
1) Power packs come with 5 year limited warranty.
He is contacting Malibulights.com for a refund of some type.
Hope he writes back and says how that comes out.
2) He was having problem and plugged power pack into wall timer, then set timer.
Heh heh, pretty clever: Malibu transformer works, but timer doesn't, so plug power pack into a wall timer!!
That being said, I had same problem with my power pack.
I used blower to remove dirt and sprayed wd-40 and tried to take it apart.
My power pack was getting electricity.
Connections were good where lights tie into wire.
My lights never turned off.
Power pack doesn't come apart.
I turned it upside down thinking water got into timer.
I took it inside and let it warm up.
It still wouldn't work so bought another one.
Then I searched Intermatic and Malibulights.com for answer, but they have no troubleshooting or repair other than check electricity and check bulbs.
Conclusion: when power pack doesn't work, it is broken.
Unless you buy a separate timer and plug power pack into that timer as Harry suggests.
After researching power packs at Intermatic, Malubulights.com, ebay etc, the best I found were tips for next power pack that might save money:
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
12/4/2010 1:04:11 AM • Malibu ML300RTW... • Answered on Dec 04, 2010
Malibu ML300RTW - Low Voltage Power Pack -300 Watt - With Timer and Ground Logo
Popular Tags
30 questions posted
Top Malibu Hardware & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Malibu Hardware & Accessories
Most Popular Question
malibu 300 watt ml300rtw timer goes
  • Hardware & Accessories
