20 Most Recent Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Questions & Answers
2answers
My ML200RT Malibu Transformer is
If the timer does not rotate, then the clock motor gears have been stripped, or the motor has gotten weak.
With most expensive timers, you can buy and replace the clock motor.
But not with the Malibu power pack.
I tried spraying WD-40 on my timer dial.
And broke the power pack apart looking for ways to disassemble it.
Power packs are one-piece units.
New power packs have electronic clock, so test your circuit with circuit analyzer before assuming new electronic gizmo will work better.
"Harry" wrote in two months ago with a brilliant work-around.
His timer stopped working.
He bought a cheap plug-in timer and then connected power pack to that timer.
Harry also said that his power pack has 5 year warranty.
He was 'negotiating' with malibulights.com over the warranty.
I hope he writes back and says how it went.
Here's the contact page.
http://malibulights.com/customer_service/contact_us.aspx
Here are some tips for next power pack that might save money:
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Another option is to take advantage of fixya phone support.
Fixya expert will walk you through the same information for a price.
1/17/2023 5:47:35 PM • Malibu ML200RT -... • Answered on Jan 17, 2023
2answers
Why do my Malibu landscape lights turn on and off intermitantly?
Look at #14 on following link http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/23/2020 9:28:28 PM • Malibu ML200RT -... • Answered on Jul 23, 2020
Dusk to dawn sensor for 24 v light system
Malibu transformer is 12 volt AC They make a photo eye for ML300-600-900 watt units, but not for 75-100 watt units http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/19/2015 7:09:52 AM • Malibu ML200RT -... • Answered on Jul 19, 2015
Ml300rtw timer stopped working
Troubleshoot on following link: http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/19/2015 6:48:04 AM • Malibu ML200RT -... • Answered on Jul 19, 2015
Just bought a new Malibu 120 runs a few minutes and shuts off repeat ly after reset
Malibu 120 has photoeye. At night, the darkness causes photoeye to turn lights ON Lights located near to the photoeye can cause the photoeye to 'think' it is daytime... so photoeye turns lights OFF... Then it's dark again because lights are off... so photoeye turns lights ON. The cycle repeats ON-OFF all night long. http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2/15/2015 3:36:31 AM • Malibu ML200RT -... • Answered on Feb 15, 2015
The lights come on and
10/17/2014 3:32:44 AM • Malibu ML200RT -... • Answered on Oct 17, 2014
Ml200tw hums but no 12 volt output
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Replace power pack Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:10:18 AM • Malibu ML200RT -... • Answered on Oct 17, 2014
My lights turn on for maybe ten seconds, then shut
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot #14 on troubleshoot Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:07:59 AM • Malibu ML200RT -... • Answered on Oct 17, 2014
The lights shine ALL the time no matter what
Plug power pack into cheap wall timer http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:05:21 AM • Malibu ML200RT -... • Answered on Oct 17, 2014
Transformer ml88l DA8812w1
10/17/2014 2:54:25 AM • Malibu ML200RT -... • Answered on Oct 17, 2014
When I turn on power source Lights flash on then immediately off
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Try power pack on different outlet/ bring around extension cord Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 2:12:02 AM • Malibu ML200RT -... • Answered on Oct 17, 2014
Intermatic wiring diagram
Try following information http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire Gene h If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/22/2014 2:44:47 AM • Malibu ML200RT -... • Answered on Jul 22, 2014
Need the pegs that start and stop the clock
Copy following link:http://waterheatertimer.org/Malibu-power-pack-stopped-working.htmlGeneh If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/6/2013 2:26:46 AM • Malibu ML200RT -... • Answered on Nov 06, 2013
3answers
I need to view a manual for this item, Is it
Malibulights.com manuals
http://www.malibulights.com/customer_service/owners_manuals.aspx
Guide for setting up lights
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack.aspx
Tips for power pack:
-Match up wattage of bulbs with wattage of power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
7/19/2013 9:10:49 PM • Malibu ML200RT -... • Answered on Jul 19, 2013
Troubleshoot
Copy following link for power pack troubleshoot:http://waterheatertimer.org/Malibu-power-pack-stopped-working.htmlAdd a comment and describe product and problem in detail. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
4/30/2013 6:19:17 AM • Malibu ML200RT -... • Answered on Apr 30, 2013
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
88 questions posted
Top Malibu Hardware & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Malibu Hardware & Accessories
Most Popular Question
need timer pins
  • Hardware & Accessories
