20 Most Recent Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Questions & Answers
Malibu 300 w transfomer trip switch sticks when
Timer motor is bad. Plug power pack into cheap wall timer http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/19/2015 7:15:55 AM • Malibu ML600TW -... • Answered on Jul 19, 2015
My transformer turns on for a few seconds and then
Troubleshoot: http://waterheatertimer.org/Malibu-power-pack-stopped-working.html If this is the digital type timer, the timer is defective. But new one. Read installation tips on link for longer lasting power pack Install surge protector Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/19/2015 6:49:36 AM • Malibu ML600TW -... • Answered on Jul 19, 2015
I have an ML500TW which does not look at all like
Loud hum = transformer going bad http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:28:18 AM • Malibu ML600TW -... • Answered on Oct 17, 2014
What would cause low voltage transformer to overheat?
Bad transformer http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:24:36 AM • Malibu ML600TW -... • Answered on Oct 17, 2014
Ml600tw
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Replace transformer. Call about warranty Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:13:34 AM • Malibu ML600TW -... • Answered on Oct 17, 2014
Need to buy timer pins
10/17/2014 2:52:31 AM • Malibu ML600TW -... • Answered on Oct 17, 2014
Voltage drops when I add bulbs to fixtures
Sensor wired wrong/ Defective sensor? Wrong sensor? http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire Read installation tips; http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
9/15/2014 5:44:15 AM • Malibu ML600TW -... • Answered on Sep 15, 2014
ML600 won't turn off
The clock module for power pack is not sold separately.Set timer to auto using override knob so lights are on, then plug power pack into cheap timer.Check outlet with circuit analyzer.Try connecting power pack to another outlet.Copy following link for warranty information, tips to help power pack last longer, links to trippers, troubleshoot, etc.http://waterheatertimer.org/Malibu-power-pack-stopped-working.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/24/2014 9:45:55 PM • Malibu ML600TW -... • Answered on Aug 24, 2014
Manual malibu ML600tw
7/25/2014 11:40:39 PM • Malibu ML600TW -... • Answered on Jul 25, 2014
Malibu transformer
Unplug transformer, change bulbs with low voltage bulbs from local hardware or home center. There are two screws on back of each bulb.Copy following link for tips to get power pack to last longer, replacement trippers, warranty, troubleshoot. etchttp://waterheatertimer.org/Malibu-power-pack-stopped-working.htmlReason for unplugging transformer: because product manual lists that as best way to change bulbs. The low voltage transformer output is 12Volts and does not carry enough power to cause you harm if you touch bare wire.Add a comment and attach photo as needed. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5/26/2013 4:53:16 AM • Malibu ML600TW -... • Answered on May 26, 2013
I have a ML500TW timer transformer I don't believe they make it any mor can I replace it with a 600
Yes, use ML 600 with 5 year warranty.Save receipt.Copy following link for useful information about getting new power pack to last longer.http://waterheatertimer.org/Malibu-power-pack-stopped-working.htmlML 600 will have 2 sets of ABC terminals.Each terminal supports 300 watts.Split lights between both sets of terminals.Use 12 gauge wire. Maximum 75' length each wire. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
4/16/2013 10:58:06 AM • Malibu ML600TW -... • Answered on Apr 16, 2013
Transformer is not turning on
1) Copy following link for malibu replacement trippers, troubleshoot overview, tips, and warranty information:http://waterheatertimer.org/Malibu-power-pack-stopped-working.html2) After reading information on link above, add a comment and describe which transformer you have, and if this is new installation, or older installation that worked before. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2/10/2013 11:49:28 PM • Malibu ML600TW -... • Answered on Feb 10, 2013
Can I install on a 20 amp circuit with a 15 amp GFCI plug? The unit says 120 v 6 amp max
Jan 20131) Yes. With 6 amps.It is not purely code, but generally not dangerous.Most household outlets and switches sold at home center are actually rated 15 amp, and should be on a 15 amp breaker. just don't overload.http://waterheatertimer.org/Color-codewire.htmlhttp://waterheatertimer.org/Troubleshoot-household-electricity.html#heat2) However if you are running close-to or higher amps than 15 amps, such as space heater (volts x amps = watts), then I would suggest installing 20 amp arc-fault breaker, and protect whole circuit.http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault3) Add comment and say what you do. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1/23/2013 9:22:35 AM • Malibu ML600TW -... • Answered on Jan 23, 2013
Malibu transformer with plastic fittings how to connect
1) Copy following link for full resources on operation, wire length, bulb wattage, warranty, troubleshoot, etchttp://waterheatertimer.org/Malibu-power-pack-stopped-working.html2) Add comment Dec 2012 for more qassistance If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/16/2012 12:37:05 AM • Malibu ML600TW -... • Answered on Dec 16, 2012
How to install Intermatic ML600TW
Copy following link for ML600 installation manual, installation tips, problem-avoidance, troubleshooting, replacement trippers, warranty information:http://waterheatertimer.org/Malibu-power-pack-stopped-working.htmlWith the ML600, there are usually two sets ABC terminals.Connect wires to AB terminals unless using photo eye.Connect 300 watts to each set of AB terminals. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/22/2012 11:44:44 PM • Malibu ML600TW -... • Answered on Nov 22, 2012
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
94 questions posted
Top Malibu Hardware & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Malibu Hardware & Accessories
Most Popular Question
ml500tw timer transformer don 39 t
  • Hardware & Accessories
