20 Most Recent Omega Seamaster 300M Auto 2531.80.00 Wrist Watch Questions & Answers
0answers
Seamaster running really fast gaining about 10min/hr!
the hairspring may have jumped up over the regulating pins effectivly shortening the hairspring this requies a watchmaker to repair.
1/25/2012 1:52:01 PM • Omega Seamaster... • Answered on Jan 25, 2012
3answers
Omega Seamaster gaining about 10 minutes per hour
Hi honestfunguy. Take it back! Omega watches are usually guaranteed for 2 years or even 3 years (Co-axial escapement), so you should not have a problem getting it repaired under warrantee. No way should it be be gaining (or losing) 10 minutes per day, let alone 10 minutes per hour. Could be any number of things, from a broken mainspring to problems with the timing regulator, but they are very complex watches and should not be looked at by anyone apart from Omega whilst in warrantee, otherwise you'll probably void the warrantee. Hope this helps; Eagle58
4/28/2011 5:09:22 AM • Omega Seamaster... • Answered on Apr 28, 2011
Train blockage
mcdevito75 here, In laymans terms yes, it sounds correct, there are a series of gears between the main spring and Balance assembly (hairspring) These series of gears control the movement of the hands, and release of the mainspring, they are called a gear train, the shafts that hold these gears in place get oiled, when the oil gets old it"ll dry up, thus takeing up the space these gears (shafts) need to operate the gear train, thus makeing the watch Fast / Slow. Cleaning and oiling restores the proper movement to the gear train of the watch, the tech. will also check and regulate (Time) your watch.
7/14/2010 6:33:24 PM • Omega Seamaster... • Answered on Jul 14, 2010
I want to know, how to change the date of a
to get some instructions copy "www.omegawatches.com/customer-service/user-manual" into your search engine and download the manual.
The index is organised on calibre numbers, which does not appear to be the number you quoted but is should be another number that is on the back of your watch.
3/13/2010 4:11:30 PM • Omega Seamaster... • Answered on Mar 13, 2010
Watch only works when not worn
You may not believe me - but I think it is You.
There are some people who stop watches from working - and affect electrical items.
These people are called SLIders - because of the original research on "Street Light Interference"
Be very careful around electrical items when you are stressed - or you could blow lightbulbs.
- Or it could be temperature this watch is responding to. If it stops when left somewhere warm - it's temperature related.
2/7/2010 8:47:32 PM • Omega Seamaster... • Answered on Feb 07, 2010
2answers
Differentiating omega model 2561.80 and a model 2531.80
Kris,
The only way to find out what model of Omega you actually own is to open it.  This should have been done by whoever you already brought it to.  Omega only prints their model #'s on the movement inside the watch.  If you open the watch, look on the movement, you'll know what model you own.
11/9/2009 9:42:12 PM • Omega Seamaster... • Answered on Nov 09, 2009
Second hand does not return to zero caliber 3606
Yes, this can be recalibrated from the outside. To get your chrono hands pointing in the right direction pull the crown out to the first position then click the plunger/ chrono button. This should move your chrono hand one click at a time to get it to the right place. If this does not work try pulling the crown out to 2nd position (all the way out) and try clicking the plunger as described above.
If this STILL does not work, which it should, then you'll need to go to an Omega dealer and have them take a look at it.
10/19/2009 5:56:48 PM • Omega Seamaster... • Answered on Oct 19, 2009
Can i change my watche ?
it is still under warranty contact the ,manufacturer customer service and ask how to get a refund for the faulty item under warranty
7/10/2017 9:54:10 PM • Omega SeaMaster... • Answered on Jul 10, 2017
Can you tell me what year is my watch model 48613181?
Have you tried contacting the manufacturer of the watch ? https://ccm.omegawatches.com/en/ I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2/28/2015 5:32:54 PM • Omega SeaMaster... • Answered on Feb 28, 2015
How do I set the chronograph on my manual Omega 1964 Seamaster wristwatch?
The chronograph resets at 0 on the recorder hands and the crono hand resets at 12:00 hope this helps.gabe
10/22/2014 2:44:32 AM • Omega SeaMaster... • Answered on Oct 22, 2014
0answers
508925
Be the first to answer 8/5/2014 3:02:35 AM • Omega SeaMaster... • Posted on Aug 05, 2014Be the first to answer
0answers
Omega Seamaster 300M Auto 2531.80.00 Wrist Watch Logo
16 questions posted
Top Omega Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Omega Watch Expert? Answer questions, earn points and help others
View Most Popular
SeaMaster Omega
  • SeaMaster Omega
Most Popular Question
omega seamaster gaining about 10 minutes
  • Watches
