20 Most Recent American Standard Colony Hydro Massage Bathtub Only AME Questions & Answers
the PVC pipes used to plumb bathtubs can be either rigid PVC pipe or flex PVC pipe. You may use either kind and is usually available at your local Home Center.
American... | Answered on Apr 10, 2015
You will need to check with the Mfg of your bathtub for new skirt.
You may find a generic front skirt at your local hardware store i.e. Lowes or Home Depot.
US Parts Center
American... | Answered on Sep 04, 2013
google its online it should show u
American... | Answered on Jun 03, 2011
365!
What about your bathtub?
American... | Answered on Feb 17, 2011
The pump is damaged or there is heavy clogging within that prevents the motor to work.
If there is wearing of the pump bearings or bushes then the rotors might get struck resulting in the hum. Secondly check the CAPACITOR connected to the motor , if the capacitor is tested and shows low value then you can replace.- simple test is to charge on the mains and see if there is retaining charge to prove it works. If not replace.
Finally remove and clean the motor and pump assembly.
American... | Answered on Feb 02, 2011
you can change out the complete air control valve. One thing i would have you do before changing that out is to make sure all of the jet faces are turned on. to do this turn the face of the jet clockwise. this will let the maximum amount of water come out of each jet face.
Sometimes if there are adjustable jets in the tub and they all get shut off, it will force the water that should be coming out of the jet faces back through the system and out the air control knob if it is open.
Just to check. that may not be the case....but...that would be cool if it were.
American... | Answered on Jan 25, 2011
try turning it so it will drop
American... | Answered on Jan 19, 2011
check to make sure the jet faces are turned on. some model tubs have adjustable jets that you can turn the face of the jet off.
American... | Answered on Jan 13, 2011
One of the quick ways to fix leaks at jets is by using Millaput two putty resins mixed and worked round the outside of the defective jet.
f there is a threaded nut on the back of the jet, undo the nut as much as possible and push the jet out into the tub. Spread aquarium grade silicone around the jet and push back into the hole, put more silicone in front of the nut, you may have to spread it in the small area with your finger or if you can squirt it in from the tube of silicone. If there is no threaded ring on the backside of the jet, go to the jet in the tub and looking down on the jet, turn it to the right. It should pop and pull out of the housing. There will be a retaining ring that may require a special tool to remove it, once the ring is out, clean it very well, spread silicon on the threads and the lip. Reinstall in the hole, reinstall jet wait 24 hours and fill and test for leaks. Take you time and you will not have to do it over again. Check where the leak is coming from, sometimes there is a hairline crack in the jet assembly, if this is the case, make sure the area is dry then use a 2 part epoxy for plastic (from lowes or home depot) and smear this all over and around the crack, let dry 24 hours, fill and test.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
American... | Answered on Sep 11, 2010
sometimes theres caps on top pop the cap and tighten the screws and sometimes there are nut or wing nuts on the bottom...simple enough for you?
American... | Answered on Sep 06, 2019
American Standard Colony Hydro Massage Bathtub Only  AME Logo
Popular Tags
22 questions posted
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
pump will not work
  • Home
