20 Most Recent
Sanyo BC-1206 Commercial Beverage Dispenser Questions & Answers
I purchased a Sanyo BB-1206 a few month ago. I
Hi:
You are creating too much foam by using 10psi and pure CO2, all commercial bars use 5 psi and the mix of CO2 with nitrogen, that is the reason why they can fill your cold glass up to the rim with almost no foam. The mix of CO2 and Nitrogen you can find it a your local gas supplier; per example; Praxair sell this mix under the name of Beer gas. Is that easy. Follow the web link to find your nearest praxair location.
www.praxairdirect.com
Regards,
Compressor Does Not Seem to Start
feel the compressor. if warm then it is being powered up and symptoms point to a compressor fault.
it is also possible that the compressor start device is faulty. remove cover over compressor electrics and check for any distressed componants
