20 Most Recent
Sanyo SR-3660S Compact Refrigerator Questions & Answers
I am moving and need
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
The freezer door is missing
Look for a gasket for the freezer on the main door of the unit. This model may not have a separate freezer door. If there are hinge pins for a freezer door and this is new, contact whoever sold it to you and report the damage. Otherwise try Amazon, eBay or Samsung to buy the missing part.
My frigde is working but does not get cold
On something like this what I recommend first is to remove the rear panel inside the freezer so we can inspect the evaporator. If the evaporator is iced up the unit will not cool properly & is a sign of a defrost cycle failure.
