20 Most Recent
Rotary Delton SDS Hammer Drill Questions & Answers
The rotary tool set collar will not grab the bits. I have never used the drill master previously. what am I doing wrong?
This photo is from a Dremel (not Drill Master) but it should be similar. Your tool may have different size collets that take different size diameter shaft bits. You may have the wrong collet (collar) for the bit you want to use.
If your tool only has one size collet then there could be debris stuck in the collet slits which prevent the collet from compressing down on the shaft bit when the top nut is tightened. And sometimes it just takes more torque on the nut that screws over the collet to really tighten it down on the shaft
My hr5201c rotary hammer does not hammer even after replacing the piston rings. I notice that when I depress the trigger it hammers. What could be the problem?
How is the health of position 21 until 27 ??? i think the impactbolt pos 24 has a problem because of the weakness of the material thats used by most of the rotary hammers in these days ,a rotary hammer is not specially made for longlasting jobs, only a few brands have had it like DUSS and Hilti but a demolition hammer is made by more expensive heavier quality materials and made for working 1 or max 2 hours at a strech , a rotary hammer cannot last that jobs.Buy a consumables kit for this machine, and the special grease for it and use only the Makita heat-resistant lubricant, because only replacing piston rings will not work beware on the lubrication when if there was something leaking in front the o-rings are all be hard and weak because when the pneumatic function is lost and its leaking in the front of the spindle is the first thing to have an good working(and not leaking) inpactbold is the highest priority for the function of the hammerfunction. the first link is having the list
Google
How do I get a drill bit out of the shaft of my rotary hammer drill snapped in it. No bit showing.
unmount the locking rings pins or ball of the toolholder while chisel is inside its possible make the parts short time hot with a burner not to long (where safety glasses ) and leather apron in case of splinters that can come off . spray some wd 40 on the hot part before use a bench vise to set the chisel in with machine on it and the beveled edge of the benchhammer on the front of the tool holder and with a second hammer beat the other site on the benchhammer to work slowly the machine will come off from the chisel. in most cases the drill guide has been worn out from the chuck in case off a cheap rotary hammer it make no sense to do it all. because it has had it working hours on it.
Where do I buy brushes for GMC RHD 1050k rotary /hammer drill in Australia? Thank you.
you probably won't as the GMC operation went broke
I am led to believe that ozito took them over so there is a possibility that the ozito hammer drill will use the same brushes
It is worth a try
other than that, many electric motors use generic brushes so may be an appliance repair shop that has a lot of repairs to hand drills and small electric motors may be able to supply a set of brushes
a sample would be a big advantage when asking around
