20 Most Recent Rotary Ryobi 1/2" Hammer Drill ZRD551HK Questions & Answers
2answers
I cant figure out how to get the old chuck off...
most are but not sure about your model.
4/28/2015 11:06:20 PM • Rotary Ryobi... • Answered on Apr 28, 2015
D551h
CJ Sinclairs 01843 869400
5/3/2014 9:12:06 PM • Rotary Ryobi... • Answered on May 03, 2014
0answers
2answers
RYOBI hammer drill model D551H dosn't start.
The problem could be somthing as simple as the cord, or the switch, or it could be that the motor has failed. There is no way to know unless you test the internals of the unit. If you are not familiar with that procedure I would take the unit to a service facility.
11/9/2013 10:11:56 PM • Rotary Ryobi... • Answered on Nov 09, 2013
0answers
0answers
Cannot remove the chuck from the hammer drill
Buy a real one, yours was made for a one weekend use, lend it to a friend, and then blame them for breaking it. YOU GET WHAT YOU PAY FOR
11/7/2010 11:15:42 PM • Rotary Ryobi... • Answered on Nov 07, 2010
How to remove the chuck of Black & Decker Drill BD154R?
You need to open the chuck and remove the bolt from the bottom of it[usually a #2 phillips].The next step is to insert a 5/16 allen wrench into the chuck and tighten the chuck.Hold the drill with the chuck facing away from you then strike the allen wrench with a hammer on the right side[so it goes down] and now you will be able to remove it by hand,good luck.
3/21/2010 12:06:58 PM • Rotary Ryobi... • Answered on Mar 21, 2010
Remove drill chuck from ryobi 18 volt hammer drill
It screws off
3/8/2010 11:13:24 PM • Rotary Ryobi... • Answered on Mar 08, 2010
Nthing happens when I hit the swithch
Probably the switch but also check the selector for the forward and reverse as it may be in neutral or stuck in neutral. Check continuity of the switch and make sure switch is receiving power.
1/28/2010 8:16:34 PM • Rotary Ryobi... • Answered on Jan 28, 2010
Hi.
it sounds like a damaged switch. It is best to have it checked and replaced if it is broken. It´s better to do before it starts running and wont come off :D
10/15/2009 5:50:01 AM • Rotary Ryobi... • Answered on Oct 15, 2009
I have a ryobi d551H hammer drill and I can't get
The spindle still spins, even in hammer mode. This model will jump out of hammer mode, sometimes you will have to duct tape it in position hammer.
8/30/2009 2:49:26 AM • Rotary Ryobi... • Answered on Aug 30, 2009
Drill quit working
what you are missing is a dewalt hammer drill.
4/25/2009 11:09:22 PM • Rotary Ryobi... • Answered on Apr 25, 2009
I HAVE A 1992 RYOBI HAMMER DRILL MODEL ED-382P WHO
As per the Ryobi web Site, there is unfortunatly no repair centers in Dallas. Go to if you go to the Ryobi website look under "support". They list a bunch of centers for Texas.
4/23/2009 10:52:44 PM • Rotary Ryobi... • Answered on Apr 23, 2009
I have a bosun pro rotary hammer drill zic dk 32 230v 50hz 1100w need a drill chuck what kind do i need
https://www.amazon.com/Hiltex-10513-Rotary-Demolition-Chisels/dp/B000QBR4M0
4/29/2020 2:58:55 PM • Rotary Drills • Answered on Apr 29, 2020
Rotary Ryobi 1/2" Hammer Drill ZRD551HK Logo
Popular Tags
21 questions posted
Top Rotary Drills Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Rotary Drill Expert? Answer questions, earn points and help others
View Most Popular
Rotary Drills
  • Rotary Drills
Most Popular Question
remove chuck black amp decker drill
  • Drills
