error 32 usually means that you are having a problem with a driver
Code 32 is an error generated by the device manager. The device manager is a native Windows tool for performing administrative action on hardware devices and their respective drivers. When a driver experiences a problem, it reports it to the device manager. These errors are not uncommon, but may be causing detrimental damage to your computer and causing the loss of functionality of one or more of your hardware devices. Hardware devices (video card, sound card, printer) utilize drivers as a resource for interfacing with the operating system. These basic functions are essential for the normal operation of your computer.
The Code 32 error message indicates that the device driver or required services associated with the driver are disabled. Drivers are often supplemented with services that provide functionality and process support for general device operations. Typically, when this technology is implemented, the services provide essential functionality for the device and may cause the device to malfunction or be unresponsive, if not active.
Common causes of Code 32...
- A required service associated with the device driver is disabled.
- The device is not up-to-date.
- The driver is corrupted.
- A previous attempt to update the driver failed or was interrupted.
- The device is not configured as the default.
- A different device is providing default functionality
if you have a few hours to spend manually pin pointing the Driver that needs to be updated or reinstalled go to the link below.
Manually Fixing Code Errors
If you are lazy enough to pay 29$ to do it the easy way use this link.
http://www.windowsanswers.net/go.php?r=driverupdate
you will be able to get a driver update software as a set up file it will scan for updates for your drivers return results of how many it found and when you hit install will ask you to register software for $29 dollars.
But before you any of that I would suggest that you go to the HP link below and hit the scan button and let HP check for driver updates for your computer.
HP Pavilion dv7 1130us Entertainment Notebook PC Drivers
