20 Most Recent
HP Compaq Presario CQ50-140US NoteBook Questions & Answers
Screen
Try going into windows color management and reset all settings. Also, try increasing notebook brightness.
7/30/2013 9:57:29 AM •
HP Compaq...
Answered
on Jul 30, 2013
My computer will not turn on at all after changing
Okay, let's review, and let me ask some questions.
A) Did you follow Anti-Static Precautions? Used an ESD wrist strap, and connected the alligator clip to a good ground source?
B) Did you reconnect the Power Button Board?
C) Fan/Heatsink Assembly;
1) Did you reconnect the fan cable to the motherboard?
2) Did you scrape the top of the Processor clean, and the bottom of the heatsink plate on the cooling tube, and apply fresh, new thermal paste properly?
3) Did you tighten the heatsink plate screws in a criss-cross fashion, and did not over-tighten?
D) Did youi reconnect the RTC battery cable back to the motherboard? (RTC = Real Time Clock.
RTC Battery, another name for CMOS battery) You did disconnect the RTC battery, correct?
E) Reconnected the Power Connector Cable?
We'll start from here.
(Do you have the CQ50 series Notebook PC's Service Manual?)
11/22/2010 12:48:24 AM •
HP Compaq...
Answered
on Nov 22, 2010
Laptop short circut
A short circuit could cause several different problems with your computer, most of which will require a new motherboard, processor, or both. Is it not powering on at all? If not, then your motherboard is most likely fried. I would suggest taking it to a local computer shop, or you could contact my business and arrange to send it in to be diagnosed and checked over. See
MADHATTER COMPUTERS
3/22/2010 3:43:14 AM •
HP Compaq...
Answered
on Mar 22, 2010
There is no touch pad device setting in my laptop
Most of the time the settings are either found in the control panel and then mouse or else in start > all programs> and control (sometimes Catalyst center) you can also right click the pointing device in the taskbar and in device settings it will allow you to disable it from here.
2/18/2010 12:08:50 AM •
HP Compaq...
Answered
on Feb 18, 2010
Compaq Presario CQ50 Comes on but the screen is
The Presario's have an intensity control for the screen.
Mine is holding the function button (Fn) down an pressing F8 for brighter, F7 for dimmer.
The marking on my F7and F8 show an asterisk indicating "sun" for intensity.
1/11/2010 9:55:28 PM •
HP Compaq...
Answered
on Jan 11, 2010
Cannot read the hard disk
do it if u r a professional..
check the following:
1)1st i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata..
open
up ur system cabinet and see CAREFULLY/THOROUGHLY if all the data cables n jumper settings
at the back of the drives (master/slave selection)..[jump this step in case of laptop]..
at the bootup (0.29sec) start pressing
briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del
as applicable)..glance in the standard settings if r detected
individually..change the 'Mode' if m/b is hybrid type (both SATA+PATA) :
Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
look if ur device itself is faulty by replacing with a standby..
2)is ur m/b compatible..check with a substitute/standby..
3)if ur hdd is making any humming noise (like 'tic tic' or 'kirr kirr')..if so it is likely to be replaced..
4)replace the data cable with a standby n see..
5)all the power connectors n data cables r properly sitted n connected..
6)reset(by picking/removing up the +3v cmos battery n resit it it again)..
7)update/flash the bios..
8)also
check the ram(s)..open it/them, rub itz teeth gently with a eraser, to
remove any oxide and or carbon formed..resit them again into the
slot(s)..
9)check for firmware update and or raid drivers (as applicable)..
10)often it does happen when there's some system file corruption..try reinstalling the OS again..
..NOTICE step3 (as listed above) CAREFULLY..
if problem persists, try contacting ur system admin/vendor....
11/7/2009 12:48:29 PM •
HP Compaq...
Answered
on Nov 07, 2009
Key on keyboard came loose
This is issue with laptops when you type fast sometime you hit the keys from the side and overtime they come loose or from overheating…the only way is by replacing the keypad…sorry.
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
9/23/2009 7:28:28 PM •
HP Compaq...
Answered
on Sep 23, 2009
Compac presario CQ62
Hello
Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine.
usually F11 or F10.
others has DVD, check and see what you have of these two.
in the first one, you recover from a disk partition the whole OS.
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too!
but be aware you have to be more specific on model, and BIOS dates.
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
