20 Most Recent
HP Compaq Presario F730US Notebook Questions & Answers
I have no internet access
NO OS STATED it came with VISA and that is a dead OS.that PC that old year , came with many options (lan)ive no idea at all what this means.sorry"run a phone line from the wireless connection to my laptop." that is impossible, wireless has no wires.NO ISP STATED (name) tech support.>? who? Comcast?NO service stated. over 6 possible....Dial up? (called phone line wired POTS)Phone line DSL ? and router.CABLE MODEM + router or all in one box>?with wifi.FIOS MODEM (and router in all cases , do you have)SAT MODEM3/4G MODEM.we have no idea at what is there.nor what wifi options are inside this PC. ever.if the modem you have , has ethernet jack (RJ45 called)then use that for fasted possible wired connectionssuper easy.!!!getting wifi to work takes hard work.x10 me blind here. step one in the laptop is.if this pc is fitted with the BOARDCOM WLAN.then. load this.sp39911.exefrom HP.here (Broadcom chip wifi driver)https://support.hp.com/us-en/drivers/selfservice/compaq-presario-f700-notebook-pc-series/3548233/model/3548236then run the wifi setup and set it up.1: get the OS drivers matching your VISTA OS.2:then load those from HP then in BIOS turn on wifi.3:now the device manager show wifi is there.4: then using the wifi control appl... set up your wifi matching credentials. SSID name, WEP.WPA1/2 method and then you password to your homes wifi net.bingo connected.
9/19/2017 3:21:29 PM •
HP Compaq...
Answered
on Sep 19, 2017
My computer does not
the start form any key selection is in the bios so get to there and check that is still turned on
9/15/2017 12:26:52 PM •
HP Compaq...
Answered
on Sep 15, 2017
Compact Presario CQ62 screen pink
OMG you think fixya is HP, sorry we are not, not by a million miles.
why should I?
this is old pc 6 years or less. and is fully out of warranty.
why would you expect free fixes, on any thing out of warranty
your car, your home, your TV or puter.
why?
we can point you to a real HP page, we are NOT HP
this is chat room full of wild kids that love to guess.
there are 5 CQ62-100 to 400 and a00. we cant guess that either.
try here. one post on pink.
https://h30434.www3.hp.com/t5/Notebook-Video-Display-and-Touch/compaq-laptop-display-has-flickering-pink-lines-all-through/m-p/1050103/highlight/true#M33974
my guess its running windows 7, right? cant guess that either.
or did you upgrade to 10, oops, that kills many things dead. ask.
reload your graphic driver, here.
see it>>??
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq62-100-notebook-pc-series/4113092
facts
this PC had 2 choices new, one is Intel HD chip and other is AMD.
so one driver will load
and if not the other will
HP driver ,ran,tell you this in REAL TIME at load.
the drivers are exe files and they all check first if you have the matching chips or aborts and tells you , wrong driver.
we dont know the history of any PC.
posted here.
if you installed a Microsoft windows disk , many things will fail.,
use only HP media to install. and win.
6/26/2017 2:32:09 PM •
HP Compaq...
Answered
on Jun 26, 2017
Orange light comes on occassionally
Tap the orange light quickly two times to enable the touchpad. Touch the same spot twice to disable the touchpad. To see the instructions from HP type "mouse" into the Search Programs and Files. Click on "Change mouse settings" and click Device Settings. Click on "Settings" and click "Touch pad disable zone". I was delighted to have found this as I had been restarting the computer manually to enable the touchpad. Shame on HP. The instructions for this simple problem are difficult to locate for the average user. They can do better.
5/8/2015 8:31:43 AM •
HP Compaq...
Answered
on May 08, 2015
Compaq Presario F700 turns off just a second after
try holding the esc button when turning on the notebook the power button light should stay on if the hp logo doesnt come on then turn it off and unplug the notebook and unplug then remove the battery plug the notebook and hold down the esc button and start it let the notebook on for about 1/2hour then turn it off and unplug it put the battery back on and plug it press the power button and it should show the hp logo press f10 to go in to bios then change time and date to current and allso change the boot order
1/31/2013 3:49:43 AM •
HP Compaq...
Answered
on Jan 31, 2013
Compaq presario cq61 will not stay turned on.
For this kind of issue, please follow up the following steps to check:1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htmIf you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Compaq Presario CQ61 AC Adapter 65Watt 18.5V 3.5AReplacement Compaq Presario CQ61 AC Adapter 90Watt 19V 4.74A
11/22/2012 8:04:07 AM •
HP Compaq...
Answered
on Nov 22, 2012
Wifi switch
unscrew the screws at the bottom of the laptop, slightly lift the upper bezel of your laptop just under the wifi switch and try to move the switch,should work,but dont be too harsh trying to lift the bezel,gently place ure thumb nail or get some old expired credit card or anything of the sort that can slide between the two bezels .
10/2/2012 6:05:22 PM •
HP Compaq...
Answered
on Oct 02, 2012
How do I switych views from the LCD to a VGA
Assuming that the issue is actually the LCD dsiplay itself, you can change to an external display by usin the fn + F4 combination keystroke. See attached image.
Hope this helps you.
Good Luck!
10/6/2011 1:53:13 PM •
HP Compaq...
Answered
on Oct 06, 2011
When I power up all I get is a white screen
1Diagnose the problem with your computer. Watch the screen from the moment you hit the power button through the time it should take to boot into the Operating System.
Adjust the computer's contrast and brightness through their full ranges to make sure that the display settings have not been changed.
Reset the computer's LCD-External Monitor display with the LCD/External Monitor key combination and reboot the computer.
Continue to Step 2 if the screen is blank throughout the booting process.
2.Adjust the screen from its fully closed position to its fully opened position. Watch the monitor for any change from a blank screen to a display or vice-versa. If the screen flashes or cuts out, the LCD panel will need to be replaced. Skip to Step 5.
3.Skip this step if your computer does not have an external monitor output.
Connect your computer's external monitor output to a known good monitor and change the display from LCD to External Monitor (the keystroke combination is different for all notebook brands). Reboot the comptuer, if necessary.
If the computer does not display to the external monitor, the video card could be bad. Skip to Step 6.
4.Consult with a professional technician to determine the cost-effectiveness of replacing your computer's LCD if you are not knowledgeable in that area.
Purchase a compatible replacement LCD and install it yourself, or pay a professional technician to do so if you do not feel comfortable performing the repair.
5.Verify that the monitor connection cables are not loose or disconnected before attempting to replace it.
Replace the monitor yourself by removing the old monitor. Remove the hinge covers by gently prying them. Check if they are screwed to the computer before prying.
Find the monitor cable's connection to the motherboard. Turn your computer over and remove any plates that may cover the point of connection. Note the orientation of the cables before disconnecting them.
Unscrew the monitor from the hinges and gently detach it from your computer. Feed the new LCD panel's wires through the same path as the old wires, and reconnect them. Secure the new LCD's hinges and replace the hinge covers.
Power up the computer and check that it works. If it does not, recheck the wire connections.
6.Consult with a professional technician to determine the cost-effectiveness of replacing your computer's motherboard or video card if you are not knowledgeable in that area.
Purchase a compatible replacement motherboard or video card, and install yourself or pay a professional technician to do so if you do not feel comfortable performing the repair.
7.Replace the motherboard by disassembling the computer. Document every connection and be sure to retain all screws and small parts in order to reassemble the computer correctly. Reassemble the computer and power it up; check the keyboard to make sure that it has been reconnected properly.
Replace the video card by removing any covers or plates that hide the card. Remove the old card and install the new card in its place. Power up the computer to test the display.
9/28/2011 12:40:44 PM •
HP Compaq...
Answered
on Sep 28, 2011
Wireless driver has stoped working
Try pressing the Wireless button. You should see the wireless LED light up.
Some laptops have power-saving enabled on the wireless adapter, so ensure that the laptop is connected to the mains power.
8/24/2011 2:37:56 AM •
HP Compaq...
Answered
on Aug 24, 2011
I'm not able to log
Hi mary dunford...
Start your computer in the "SAFE MODE"...To do this Press the F8 key upon start up, and keep pressing till it starts in the safe mode.
Once you have it started in the safe mode, then you can go to:
Start>Control Panel>User Accounts...you can then delete the account or change the password from there...
Please take time to rate me
8/12/2011 1:22:42 AM •
HP Compaq...
Answered
on Aug 12, 2011
I forgot my administrator password
have you changed admin password recently ? if yes and if you remember the old admin password, you should go ahead and restore the laptop to it's previous point when new password was not set.
restart the notebook and keep tapping f11 key until Recovery manager window appears.
under I need help immediately, select Microsoft System Restore
click next
in Vista, you will find System Restore under Advance option.
8/12/2011 1:17:37 AM •
HP Compaq...
Answered
on Aug 12, 2011
My wireless light stays orange when the switch is
I have also faced
the same issues which you are facing and my friend told me about "ijinni
technician". I contacted them at www. ijinni. Com. For any issues just
open the website and you can chat with the experts who are Microsoft certified
technicians and will fix the issue itself on the spot or u can call them
through Skype. For more visit their website as it is very user friendly
website. Just click on the chat as the response rate will be very fast from
them and they have fixed my issues in no time.
There are 4 ways to reach them.
1. Once you open the website just click on the live chat
where one of the IJINNI technicians will be in touch with you.
2. If you have Skype installed in your machines just click
on skype icon on "ijinni.com" to make a free call.
3. You can email at [email protected]
4. You can dial at +1 512 879 3546.
For any issue you are facing with the computer just call
IJINNI
3/30/2011 6:57:17 PM •
HP Compaq...
Answered
on Mar 30, 2011
Compaq Presario F730US doesn;t recognize the
Your problem that you are experiencing is either hardware related or software related.
Hardware related in the sense that it is not connected or the actual touchpad it faulty.
Software related in the sense that the drivers need to be reloaded.
A technician will be able to diagnose the problem source, claim warranty support if you can!
Thumbs up!
damnor01
2/25/2011 7:31:14 PM •
HP Compaq...
Answered
on Feb 25, 2011
Presario f700 has a black
Sounds like it could be a couple of things, but what I would suggest you do first is when you power on your device, insert the Windows CD that came with your Laptop and boot from the CD as opposed to the HDD.
Once the drivers are loaded, it will give you several option on how to restore, fix or if necessary, reinstall the operating system from scratch.
It sounds like you BIOS info could have been corrupted and that could be why it goes through this start up cycle constantly. By bypassing the HDD, which could also be corrupt and booting from the Installation CD I mentioned above, this will allow you to gain access at least and have the options listed above in order to get you laptop up and running again.
If you require further assistance, please contact me.
2/18/2011 2:49:21 PM •
HP Compaq...
Answered
on Feb 18, 2011
