SOURCE: D4 Rainbow leaking water around the water basin
Clean the water separator. Use a tooth brush if you do not have the Rainbow separator cleaning brush. It is the same thing, and works perfectly. :-)
Ralph
Make sure the bowl has the pin on it. The Vacuum has switch in the bottom that keeps the Vacuum from running if the bowl in not on or the little pin is broken off.
Ralph Wakeman
