20 Most Recent
Rainbow 75th Anniversary Canister Vacuum Questions & Answers
Changing the filter in Rainbow e series
Some of the e-series has a corrugated filter in the top section. To get to it, remove the clear plastic panels that are the sides. Most have 3 screws on each side to move, then the top half will come loose. There also is filter on the back, there is a door to remove to get to it.
I bought my rainbow se vacum 4 years ago and I was
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature.
It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Cleaning the separator
Try spraying something like WD40 around the shaft, then if you have to, use 2 small flat blades that will fit under the edge of the separator and keep working it until it pops loose. It is just crude and calcium from water that is keeping it on.
