20 Most Recent Rainbow E series Canister Wet/Dry Vacuum Questions & Answers
It sometimes takes a good soaking with water in the tank for a while. Maby a Week or longer, and it also takes a little running time. Not more than 10 minutes at a time, then cool for 30 minutes inbetween runnings, for the water to pump out of them. Do not even hook up any hoses, until it pumps water.
Thank you,
Ralph
Rainbow E series... | Answered on Oct 08, 2019
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Rainbow E series... | Answered on Jan 19, 2019
Our company provides a clean and sterilization service. You can see here...
Rexair Factory Authorized Rainbow Vacuum Repair Center
Rainbow E series... | Answered on Jan 17, 2019
Hi. I found it on amazon, here: Amazon com rainbow vacuum manual. I hope I have helped. cheers
Rainbow E series... | Answered on Dec 08, 2018
[PDF]Rainbow Vacuum Schematic - WordPress.com
https://carniomosdirt.files.wordpress.com/.../rainbow-vacuum-schematic....
We carry the Rainbow Vacuum e2 (Black) Main unit parts. to our schematics page and download the schematic that ... Question about Rainbow E series Canister Wet/Dry.Vacuum ... We carry everything from the OEM electrical cord,. Upright .
[PDF]rainbow vacuum manual repair.pdf - WordPress.com
https://arahentau.files.wordpress.com/.../rainbow-vacuum-manual-repair....
Recent Rainbow E series Canister Wet/Dry. Vacuum ... Rainbow Vacuum E SeriesFilter Queen Vacuum Wiring Diagram Oreck rainbow vacuum cleaner.
Rainbow E series... | Answered on Aug 14, 2018
Could be switch, cord or motor. If the switch has alot of play it is usually bad. Check cord for damage.
Rainbow E series... | Answered on Aug 05, 2018
Could be several things. Bad switch (does it have a lot of play in it) Bad cord , check for damage. Or bad motor.
You put hose on rear of unit and use the inflator tool. Be sure and replace rear cover when finished.
Could be several things. Bad cord, bad receptacle on rainbow or bad motor on power head.
Gasket is not sealing tight.
Locked up bearing.
Check bearings on beater bar and stem on motor. Use your finger to make sure they all roll smoothly and if they are very noisey. If any of these are bad the unit will shut down.
Pump may be bad but check the lines to make sure they are not clogged.
Do you hear the pump running?
Rainbow E series... | Answered on Jul 05, 2018
Try putting on a new belt.
Rainbow E series... | Answered on Feb 13, 2018
You may have damaged a bearing or bearing housing and that could be causing the motor armature and field to rub together which in turn causes the motor to draw a significantly increased current to overcome the friction. It could be a simple fix if it is a bearing but if it is the housing then it is likely toast. I used to repair motors years ago and the cost then was not bad. However if the motor is heat damaged, as happened to my power rack last year, it was cheaper to buy a new one than replace the motor. A burned out motor is not worth repairing these days.
Rainbow E series... | Answered on Dec 21, 2017
You can get a Rainbow vacuum Hepa filter here:
Rainbow Vacuum
Hepa Filter
Rainbow E series... | Answered on Dec 13, 2017
Rainbow E series Canister Wet/Dry Vacuum Logo
587 questions posted
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Robert McClure
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Rainbow Vacuums
  • Rainbow Vacuums
Most Popular Question
rainbow pn 2e circuit breaker
  • Vacuums
